Hi guys,
just wondering if someone can help me.
I have attempted to replace the belts for the power steering and also the air conditioner. I have loosened the adjustor bolts, however cannot seem to move either the idler pulley or the air con unit, to release the tension.
What am I doing wrong???
Cheers
Edited by jonathon
the idler pully for the aircon belt has a bolt behind it that is used to tension it and loosen it you need to acess it from under the car basically when your underneath looking up at the idler the head of the adjuster bolt is pointing at you towards the ground the aircon unit its self is fixed to the block and doesnt move
Hi SWITZER,
I have loosened the adjuster bolts - but it still wont budge. I'm even thinking that the belts are too small for the car, meaning they have been adjusted as much as possible, therefore I cannot make them looser.
I was considering cutting the belt off then seeing if it can move (but if I'm wrong I wont beable to get a belt back on!)
So there are no other bolts that need to be loosened, just the adjuster bolts (one under the idler, and one under the power steering)?
Are you sure youre loosening them?
The aircon tensioner pulley should move UP as you loosen it. You might even want to take the bolt all the way out.
The PS pump should rotate down and towards the motor. You may have to loosen the mounting bolts and push/pry on it to get it to move.
My dad told me this once: Somehow someone put that belt. You should be able to get it off.
You need to loosen the bolt holding the tensioner pulley itself on before it'll move up or down (air con). To loosen the PS bracket bolt you can fit a 14mm socket through one of the gaps in the pulley as long as it's rotated into the right position to do this.
Edited by doo doo
Do you mean the idler pully? So the bolt in the centre of the pully needs to be loosened?
DanShirts - great quote from your dad!
"My dad told me this once: Somehow someone put that belt. You should be able to get it off"
Cheers guys
No not the bolt in the center of the pulley! There is a bolt on the left hand side of the pulley which can be accessed when looking through one of the 2 holes if the pulley is correctly rotated as mentioned by doo doo
Don't take it all the way out like i did though just loosen it otherwise it's a bitch to get back in! :verymad:
Edited by endless
The nut in the centre of the tensioner pulley for the aircon belt needs to be loosened- this nut locks the pulley into place. (not the PS pulley).
Edited by doo doo
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
