hi guys,
just a quick one. Someone from ACT called me this morning about the car and asked if i could get a road worthy certificate, i said that's fine but I was under the impression that if the car went interstate, a VIC RWC is not actually going to mean anything?? Wouldn't it have to get the equivalent for whatever state/territory it's going to?
cheers,
daniel
yeah the vic one won't mean anything other than it was found to be roadworthy in victoria....it still requires an ACT roadworthy certificate, which is *supposed* to be issues by the RTA place here given that it's an import and modified...any buyers in the ACT will be hard pressed to get your car registered here, unless they know someone who can do a roadworthy certificate....even then it won't be legal as such, but may still get it registered.
I almost considered your car on that note :) if I didn't already have a 33
If they're changing rego they really need both.
When i bought my supra from VIC i had to take to the government shopfront all the VIC roads crap + a ACT road worthy certificate. the certificate only needs to come from an approved certifier, not just Dickson.
Mine had no issue it was very much stock at the time. If its fairly modified then it'll probably end up at Dickson, unless he can beg a place to do it. When going to Dickson make sure they tighten their butt cheeks as it wont be pretty.
I was under the impression that ALL imports and ALL modified cars must go to dickson. If it was just interstate, but neither of the previous, it'd be fine to go wherever...
I got mine passed at Lanyon, but it's stock enough that the dude didn't really care. Only knocked me back on tint (5%) which was fair enough, and then the shopfront only wanted ACT roadworthy+QLD rego papers.
hi guys,
cheers,
daniel
Correct. I bought my R34 from VIC and the guy was going to get one but I said not to bother.
Maybe your buyer just wants to see if it can pass VIC rego to give him an idea of what he might get picked on with ACT rego (I know the rules are different).
haha yeah probably :verymad:
but if it passes a VIC roadworthy it might be in with a shot... VIC is supposedly more strict than us! You're not even allowed 2 intake mods there (ie, can't have a front mount AND a pod!)
i took mine to premier automotive in mitchell and they passed it no worries, it was stock at the time tho...
I been looking closely at your car there and it'll be awesome if it ends up in the ACT!!!! :verymad:
I know about the car doofus! I actually read about it on another forum in which he copped a pasting (Daniel will know what i mean :verymad: )
But it's registered in Vic right? So it's not "unregisterable"! All I'm saying is the potential owner might be investigating how hard it's going to be here.
haha, yeah you're right Pat :verymad: sad how a car's material value in no way reflects what it's worth on the market, else I'd be accurate in my offer :cool:
Definitely the absolute sexiest GT-T I've ever seen. Ever.
yeah, only 1 intake mod, that's why i put a return flow FMIC in so i can run the stock airbox with highflow filter.
would it be that hard to rego? it's definitely quiet enough, no hole cut FMIC (return flow), turbo looks stock, can't see injectors/pump/afm - nistune will read like a stock ecu when plugging in a consult, brakes lines are ADR - i guess the only thing possibly is height, but the suspension is adjustable so that's an easy fix. I don't know the ACT rules but i can't see there being any major problems?
they're just bilstein shocks with extra circlip grooves to adjust the height. It's not like you'd pop the bonnet and see something sticking out of the strut towers, so if you raised the car, i don't think you'd know they were adjustable in the typical sense.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
