I should be safe in assuming we are all paying the same/similar amount but just wanted some feedback.
My m35 is due for registration in 3 weeks time, the RTA side of things is $407.00 this year, $11.00 up on last year ($396.00).
What are you guys paying?
Just seems expensive, is it because it's an import or because the government likes to bend us over just as much as nissan australia? :)
The only other vehicle I have registered this year was my motorbike and it was only $100 and something.
Anyway, just thought I would put it out there to see :(
https://www.sau.com.au/forums/topic/326174-m35-nsw-rta-fees/
Sorry I'm in Qld but I would love to only pay $400. I just paid 12 months over $800
sorry misread your post. Our rta side of it is about that much too
yeah, minus greenslip of course!! my greenslip this year is $480 :) can't remember who it's through but I might have to shop around this year :(
Yep mines due in a few weeks too $407
Thanks heaps for that man, it's always good to check these things. The RTA doesn't "always" get it right if you know what I mean?! :(
Yep, another high quality government agency :)
It's calculated purely on vehicle class and weight. . that is it. . they are not fussed if it is an import etc. . .
Greenslips are slightly different but they rely more upon postcode and age and use of vehicle eg Private v Business, people complain about greenslip prices. . but those who are injured in car accidents would disagree..
Yep, exactly - weight and vehicle class are used to determine the RTA rego cost.
$407 to the RTA, $678 for ctp with GIO, ouch
A major reason for higher CTP greenslips in NSW is the new Life Time Care Scheme which covers catastrophic injuries regardless of fault and the no -fault child scheme and at-fault ANF for drivers.. The MAA have a LTCS levy. You will see it in the cost breakdown of your greenslip. Plus the insurers margin of course.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
