16x8 +28 mesh wheels set=4
multistud 4 and 5 114.3
2 have gone tyres other two are just above indicators.
wanting $250 let me know asap want these gone
pic of two of them other two are exactly the same
https://www.sau.com.au/forums/topic/326190-16x8-28-mesh-wheels-set4/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
