Involve In A Car Accident Needs A Few Bits And Pieces
Long story short, stupid bitch driving a swift on Lutwyche rd heading outbound on the far right lane couldn't stop in time for the car in-front waiting to turn right, smash her car into the corolla and decided it was cool to hit the gas pedals and turning her steering wheel to the middle lane, side swiping my right rear door, rear quarter, my side skirt, rear arches and wheel in the process, and then bounce off hitting me in the rear.
Right now I'm waiting on the 3 different accessor from different insurance company to quote/access the cars but in the meantime I need to find a few places that could fix/supply HKS Hipermax suspension, Cusco Upper Arms, Cusco camber kits. Any recommendations and/or experience with the said company would be greatly appreciated.
Thanks in advance fellow SAU'ers.
I'm with Just-Car, they told me even-thought I'm not at fault it will still have to be one of there approved repairer to repair the car. I have the option of going to my own repairer but they will no longer give me the agree value of the car and also they will void my life time repair guarantee.
Hey Mikey. Was she insured. If so then wont her insurance company have to approve your repairer?
Mick
Mick
Thank GOD she had insurance!!! Her insurer(RACQ) does not care which smash repair I go to, as long as "all repairs must deemed necessary". I personally don't know what's that suppose to mean???
Edited by MRR34
Sounds like you're doing far too much dicking around. Call Just Car, give them the woman's details, tell them to contact RACQ and work out between them who is to repair/how it's being repaired. Just make sure you tell them that before any work happens that you have to authorize it.
Stop wasting time on the phone and make them do it.
Maybe I'm doing far too much then I should, but I rather spend a few more hours and dollars to get what is best for my car, then to end up paying a second time to fix the stuff up.
I've given all the details to my insurance company including a police report that goes with it, but at the moment she is denying anything and everything. Her defense is "The car infront of me stop suddenly without reason, therefore I could not stop in time, BUT I try to avoid him by moving into the middle lane which unfortunately hitting both cars in the process.".
Either way thank you all the SAU'er for helping me and giving me assistance in this case.
Mikey what the car in front of her did is not your problem. she needs to sort that out with them. But yeah let your insurance company handle the lot
You don't have to pay if they stuff it up. If Just Cars say it has to be repaired through who they say and don't let you use your repairer, and you're not happy with the work, then it's Just Car's responsibility to get it repaired a second time until it's back in the same condition it was originally in. The only time you'd have to pay more is if the car wound up being in better condition that it originally was. Haven't you ever read your policy?
It doesn't matter how much she denies it. She's at fault pure and simple (failure to leave a safe stopping distance in front of her car, and failing to give way while changing lanes). They have your statement, the other person's statement, and her statement. The insurance company handles it all from here. You don't need to be involved until they tell you where to take your car.
i had to bold it for truth lol
Nice john.
But even if it goes through either insurance companies repairers, arent they guaranteed for life?
Get it done by your insurance company. It's their job to hunt people for cash. =)
Lucky the cops didnt say its your fault because you drive an import. =P
It's only guaranteed for life if it's in the agreed policy from the insurer.
It will be done by his insurance company. Just Car use their repairers, pay the repairers, and RACQ pay Just Car. This is why he needs to stay out of it. The insurance companies handle this stuff every day and don't need people stepping on their dicks and getting in the way.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
