  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
Update
Engine just had a refresh and a check up, reason being the balancer sheered the key in the crank and damaged the crank collar. Brand new r33 Gtr crank( balanced) with new bearings put in to replace the old ones
it now has a ati balancer on it also.
Inner and outer tie rod ends and upper camber arm bushes were also replaced while the engine was out.
12 months rego just put on
Price is $32000 firm
I purchased the car from Autostyle, this is the second motor, the first engine I was told it was a Jun built engine when I bought it, but I found out it was a standard engine with head work and bolt ons when it popped.
  • 3 weeks later...
  • 3 months later...
  • 5 months later...
  • 1 month later...
  • 2 months later...
Just an update:
Car is getting new front and rear window seals put in and some body touch ups, price is $27000 firm
12 months rego also put on, and also getting a full service done once the seal are in.
  • 2 months later...
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
