Hey Guys
Up For Sale is this Black 1999 R34 GTR
Only 81,000 Kms
It Features
New Tein Super Street Coil Overs
New Carbon Fibre Body trim Kit
New Volk Racing GTV 19inch in Silver
New Hankook Evo Tyres
New Apexi Power FC D/Jetro Computer
New HKS Turbo Timer
New HKS Boost Controller
New HKS Fuel Pump
New HKS Front Pipe
New Kakimoto Stainless Steel Exhaust
New Nismo Oil Filler Cap
New Nismo Radiator Cap
New DBA Slotted Rotors
Asking $49,999.00
Call Dave/Kym 0415555577 or Work 02 9725 5577
Edited by Blitz
https://www.sau.com.au/forums/topic/326597-r34-gtr-for-sale/
Guest
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
