i think the first one it by far the best :)
now u must tell me how to do :):rofl:
Lol no way, it's about as cool as a fake bov
am curious, can you only get flames going without a catalyct converter?
That or very rich tune, or like the op, a flamethrower kit.
https://www.sau.com.au/forums/topic/326879-flame-on/#findComment-5322173
No cat, rich tune, atmo venting bov.
I used to get bigger/more predictable flames when under load, made tunnel runs amusing :rolleyes:
hahahha went on one the other nite with a vs ss chasing me so i slowed rite down and let the flame kit backfire... it was so loud omg.. hahhaa he soon backed off. :cool:
https://www.sau.com.au/forums/topic/326879-flame-on/#findComment-5322601
