I've got the standard rb20 plumback bov on my rb25 (r32 with 25det and highflow) but its just way too loud even on 10psi, sounds like a stupid aftermarket hks gay one.
I was considering putting a gasket with a very small hole on the bov, limiting how fast it can vent the air to try and quieten it down.
I like the sound the pod makes so I don't really want to remove this, is there any easy way to keep the induction noise but quieten down the noise when you throttle off? Is my idea likely to work?
Edited by Rolls
Restricting the size of the bov orifice in an attempt to decrease the amount of air it can vent, will just cause more flutters... I don't think you'll be able to get less bov noise without also getting less induction noise (i.e. change filters).
either rb20 bov's are pretty loud or yours and my definition of loud is different, ive got a r32 gtr bov on my rb25 and i dont think its loud at all, i had an apexi dual chamber bov on there before (a fairly quiet atmo bov) and the gtr bov is much quieter.
Edited by jimmys-33T
Well it is quieter than a proper aftermarket atmo venting one, but it still is loud enough for people to look at you like a dickhead everytime it comes on boost.
Its a skyline, you automatically have hoon tattooed to your forehead when you drive it. Wear this with pride.
Yeah, I used to have a 2 door HR31 and you got lots of 'wow I have never seen one of those before' looks now I just get 'wow you are a dickhead'
:D
Edited by Rolls
GTR bov will probably be quieter at 10psi, they only start to get loud when you run lots of boost. Get a GTR bov :)
What is the difference, just a stronger spring? I wonder if there is a way to open it up, would be easier if I could just preload the spring in mine with a few washers.
Made a gasket out of a coke can, cut a square hole about 1cm^2 in the middle, put it on top of the original metal gasket and did it up as tight as I could. Result was very quiet flutter and no BOV noise, the car is also much faster so I'm guessing the old one was leaking boost for whatever reason, or possibly was opening up whilst on vacuum making the turbo work harder.
Highly recommend it to people who want flutter but not annoying VL dose style, or if they want to quieten down the bov noise, I'm sure if I made the hole slightly bigger it would be even quieter again.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
