ITEM 1:
Bosch 044
Original made in Czech Republic
Brand New never used or installed just opened the plastic packet slightly to test fit banjo fittings
Will suite S15 R32 R33 and can be mounted in tank with supplied banjo fittings and fuel sock
Also Includes
Banjo Fitting, Nut & Copper Washers
One way valve (Without this its hard to start your car as the fuel pressure drops and fuel goes back through the pump to the tank)
Fuel Sock/filter so that the pump can be mounted in tank and wont suck shit from the bottom of you tank into your pump
Price: $200 posted / pickup
ITEM 2:
Sard Fuel Regulator
200kpa - 800kpa
Original not a copy!
Never used just opened box to have a look comes with original instruction and in original bag.
Also Includes
Speco Fuel Gauge
0-100psi
Brand New Never Used still in orgininal packaging
Price: $140 posted / pickup
ITEM3:
XTR Fuel Pump Bracket
Designed for mounting a Bosch external fuel pump
Brand New never used still in original package
$30 Posted / pickup
If you would like any close up pics plz let me know.
Edited by DJSimmo
would the pump fit a gtr33 and wats last price
yes it will fit the R33 GTR. The with the filter sock and banjo fittings it will make the installation quite easy. Best price is as listed.
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
