Hey guys,
I don't know much about computers, but I'm looking to buy a new PC so I can play the new Starcraft and other modern games avaliable (or soon be released). I want to run them all well, but it need not be a powerhouse that can play everything on full graphics.
I've been looking around a budget gamer PC builds, but I really don't know what exactly I need or when its worth paying more to upgrade.
I came across this one:
https://ipspty.com.au/index.php?comp=i7-pri...ster&tech=1
Which seems okay, its around $1250 without any OS. I was hoping to spend no more than $1500 for the tower alone, I can supply everything else.
Could anyone point me in the right direction towards a good supplier, or even recommend me a pre-made PC like the one I showed? I'd greatly appreciate it.
Cheers.
https://www.sau.com.au/forums/topic/327161-gaming-pc/
So is $1500 your limit?
Also what screen size/resolution you running?
Nothing wrong with AMD processors however you really want to go socket 1366 with Intel at the moment.
The speed of the i7's is just too good to pass up, and you'll easily be able to get 3.5ghz (closer to 4ghz) outta the processor making it a very nice machine.
The 4350 video card though is a joke. It's old design and slow as shit for new gaming. You'll need something more like a 5850 ($300)
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5323955
you don't really need an i7 for gaming i5 will do fine, as especially in lower resolutions, the GPU appears to be more of a bottleneck.
Also from what I've read you're much better off spending the extra cash and getting a 5850 vs a 5830
I'd go one of these http://www.scorptec.com.au/system/109 with a 5850, that's $1500 well spent. It can be cheaper to mix and match parts, build it yourself etc, but generally Scorptec have really good service and their machines are well built in regards to cable managment etc.
It also has an i7 :D
oh yeah and that stuff you linked to is pretty much ebay crap. Asrock mobo? 4350? EWW EW EW
Edited by bozodos
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324382
The issue with sticking with i5 though and the 1156 socket is there is no upgrade path.
It seems at this stage with Intels next architecure move that 1156 will no longer have a home and 1366 still will.
For me that is the single biggest issue at the moment as i want to upgrade as well but nothing is "100%" firm so im holding off.
If there is a decent successor plan for the 1156 socket i would say i5 is indeed a good choice.
However as it stands currently, it is not. (unless there has been news leaked in the last month, ive not been checking much lately)
Also a 5830 is a shitter card.
The 5870 for 15% gain over a 5850 is more than 25% the price so the 5850 is by far the best value card at the moment.
They are a tad faster than the 4890's of last series.
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324453
ATi wont be releasing new cards for a while :D
5850 is currently a very good compromise.
Although i did see one for around $230 the other day which is CHEAP... also a 5870 for $320 which means prices everywhere else will start dropping shortly.
Well i wouldn't upgrade mobo if there was a nice upgrade path for the CPU.
You already have decent DDR3 memory options, GPU's and so on. In 18months time you could just upgrade the CPU to the newest stream and it would be fine again for another 18-24 months.
CPU hardware is @ such a point now that for gamers that i cannot see a i920 being "maxed" for 18months, and in the event it does a simple upgrade to the new set will solve any issues.
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324516
Yeah but with the 1366 i can see people easily getting 5 years out of it currently as it stands without much of a worry.
maybe just a GPU upgrade
otherwise RAM & mobo's will be fine as long as you get a SATA 3.0 Mobo, you'll be running fine.
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324557
even with SSDs in RAID0 sets SATA 2 is rarely saturated. USB 3 maybe.
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324676
Thanks for all the advice guys, think I'm going to go with the package bozodos suggested. Is there any decent things I should be considering upgrading on that package? Also looking at getting that LG w2343t-pf monitor as its pretty obvious there's no point having this great machine without a monitor to keep up with it, and all the reviews I read for it said it was a great screen for its price.
Cheers.
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324681
Are you going to build it yourself or pay them?
Ill check prices when i get home and see if its worthwhile (no time from work)
Yeah i know SATA II is flooded, hence i said SATA 3 (III), 6Gbps.
Get a x58 with that and you'll be laughing.
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324712
I was saying SATA3 is unecessary. A $1500 or less system is not going to accomodate drives that will come close to needing SATA3 or indeed most X58 boards that have SATA3/USB3
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324726
Ah misread... :D
In 2 yrs SSD's will be nicely affordable, and signifigantly faster potentially. If you prepare now you can freely swap drives out as well.
That's if they don't go the route of PCI-E SSD's like OCZ just released.. fking cheap and fvking fast, i was most impressed.
The x58 IMO is a perfect choice for the moment.
Costs marginally more than the 1156 sockets, but much more flexibility over the next 4-5 years for minor updates to make your dollar go as far as it can.
This is what i mean when i say a bit more long term.
That said im going to build a i3 media box soon, power & heat friendly and still packing a good punch forever :)
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324756
Ah misread... :P
You can get an 1156 that will meet his requirements for around $130, even a crappy Asrock X58 is still $200. i5 750 will play all the latest games at $248 while the lowest i7 (still better than the i5) is $350+ i7 jacks up the cost pretty quick and then eats into the money available for a GPU which you'd want to be able to do 1920x1080 with vsync.
The i5 OCs fairly well too.
I like spending other people's money too but 'gaming pc' is a very loose term, just look at dezz' FS thread, lolerskates.
Edited by DivHunter
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324795
yeah well there's more than one way to kill the proverbial cat here. Like I said Kez, go the 5850 option and you'll be sweet :P
I have a Benq monitor at home, good screen for the price. Dell Ultrasharps look better, but cost a lot more haha.
and come on guys it's a 1500 dollar machine, not a 6 grand uberpwnage LAN brag rig lol, I only know of one person who runs an SSD and that's in an Alienware laptop!
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324801
MSY are selling 920's now for under $300, and UD3's from GB are around $200 (similar price to ASRock ones now)
So whilst cost is more, you are looking at less than $200 in total spending for 1366 which IMO is quite reasonable.
I do agree the i5 is cheaper & also they will run any game market now (and clock hard). Depends on your view of the following really:
There is no such thing as "future proofing" a PC build, but i like the ability to have a cheap & easily flexible upgrade path.
1156 doesnt offer it at this stage, it still could change but is a gamble.
If Kez plans to upgrade in 2-3yrs time, then 1156 is dead spending, better off throwing $200 more @ 1366 and then only having to buy a new CPU :D
I could argue all day with ya on it lol, but i do see ya point as I'm sure you see mine :)
haha and yes, that thread has made me chuckle once or twice :P
https://www.sau.com.au/forums/topic/327161-gaming-pc/#findComment-5324833
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
