1995 NISSAN SKYLINE R33 GTS-T
Kilometres: 67,000
Interior Colour: Black
Colour: White
Transmission: 5 speed Manual
Body: 2 door 4 seat COUPE
Drive: Type Rear
Engine: 6 cylinder Petrol Intercooled Turbo 2.5L (2498cc)
Reg Plate: 1DHI797
Reg Expiry: NOV-2010
Road Worthy: Certificate Yes
Vehicle ID: 8706184
Brief Comments: Only one in WA! 1of 3 in Australia. Genuine & Fully modified by Tommy Kaira M25. Serious buyer only.
This has been a long and thought out decision to sell my pride and joy, basically I am now decided to go back to my home country, so this rare skyline has to go.
It has been recently serviced and all fluids were changed, it has done 67,000km from new and it shows everything on the car is still like new, rego has about 6 months left.
A genuine Nissan Skyline R33 Tommy Kaira M25, only one is WA. 1 of 3 (Unique) in Australia and 1 of 400 worldwide, fully modified and tuned by Tommy Kaira, spec list is as follows:
-Tommy Kaira ECU rpm limit to 8250rpm 330bhp.
-Tommy Kaira Coilovers,
-Tommy Kaira Intercooler,
-Tommy Kaira Uprated injectors and fuel pump.(tomei fuel pump),
-Tommy Kaira Forged internals,
-Tommy Kaira Camshaft (tomei),
-Tommy Kaira Turbo steel internals
-Tommy Kaira Instrument cluster goes to 300kph and 10.000rpm!,
-Tommy Kaira 3 gauge cluster in centre console.(exhaust temp/oil temp/boost,
-Tommy Kaira Floor mats,
-Tommy Kaira Foot pedals,
-Tommy Kaira Lightened flywheel and upgraded double plated clutch,
-Tommy Kaira 18" split rims,
-Tommy Kaira Titanium wheel nuts,
-Tommy Kaira Full body kit,
-Tommy Kaira Sway bars front and rear,
-Tommy Kaira Signed and numbered plaque,
-Tommy Kaira Steering wheel, pedals and mats,
-Tommy Kaira 2 way diff 1.5lsd,
-Tommy Kaira Spark plug cover,
-Tommy Kaira Aluminum radiator
This car at the moment needs for nothing and there is no problems with it what so ever. Comes with all the documents. Any inspection is more than welcome.
For anyone who is a genuine interested, I can go out and get fresh photos of anything on the car.
I am looking for around $18,500 ono for this rare performance vehicle. It is a Nissan Skyline R33 Tommy Kaira M25, 1 of 3 (Unique) in Australia and 1 of 400 worldwide.
Remember! This is the only one in Western Australia!
0401167028
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
