hi all
recently ive had trouble with my rb25 since my regrettful turbo upgrade ive been told to add injectors and ECU into it to sort it ive bought a APEXI POWER FC and SARD 850cc injectors but im a bit worried about putting them into a stock engine i mean surely increased injection would make alot more heat and strain on the engine so what do i have to do to prevent it from exploding after i spent so much on it, forged pistons??
https://www.sau.com.au/forums/topic/327290-plz-dont-explode/
What turbo did you put on. That's the million dollar question.
Don't run an aftermarket turbo on the stock setup so yes injectors, fuel pump and ECU are a must at the minimum. Engines don't just explode. Detonation is what kills engines which all comes down to the tune. Having a large turbo on a car on a stock setup is a lot more dangerous than running a bigger turbo with all supporting mods keeping it all running right.
By the sounds of things i'm assuming it was just a slightly larger turbo upgrade, possibly highflow? Regarding your injector choice you may have gone a bit overkill, but once again, comes down to what turbo you put on there.
Need more information man.
You need to start reading the Forced Induction section to get a better understanding of it all.
EDIT: Don't worry I just found your other thread, i'll read that and reply in there.
Edited by PM-R33
the bigger injectors themselves aren't going affect the engine. you could put 10,000cc injectors on a stock engine and it won't affect it at all because you then tune the ecu to only allow the injectors to put in the same amount of fuel as it was before.
what will put more stress on the engine is the turbo. this then pumps more air into the engine, and therefore you have to put more fuel into the engine to balance it out.
so ok the injectors wont harm the engine bcos they are set to match the air intake with fuel (more air, more fuel) ok. what about a fuel regulator will the stock regulator be able to run injectors as big as 850cc coming from a stock setup or will it be wise to get an aftermarket fuel regulator if so which one?
as PM-R33 said, its all in the tune. normally if you have big injectors, a higher flowing fuel pump and bigger turbo you'll have to tune it anyway. you dont have to change the fpr for your application, its not really necessary unless for some reason you want to fine tune your fuel system or running ridiculous amount of power.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
