Hi Guys,
I have taken both of my rear qtr windows out due to a bit of rust on one side. However I have run into a little bit of a problem. The side with the rust I just used a dremel to take out all the sticky black sealant they use to stick on the window because I will repaint this side anyway so if I accidently take off any paint it wont matter... But on the otherside there is no rust at all and the paint is 100% perfect so I dont wish to use the dremel to take out the black sealant as it will stratch the paint. I would prefer to take off the black sealant and leave the paint intact so the window can just go straight back in.
Is there any solution that you guys know of which will take off the black sealant without damaging the paint? Wax and Grease remover doesnt work and thinners (which I experimented on the window with the rust) will take off the paint. The only option I can see personally is using a blade but that leaves some risk of slipping and stratching the body work which is not good if I wish to get a good seal again on the window.
And before you guys ask, yes I am using a professional spray gun and have my own personal spray booth no 2 dollar spray cans here. =P
Any help would be of great help guys!
Cheers.
https://www.sau.com.au/forums/topic/327446-rear-qtr-window/
Hmmmm... Having been here before a couple of times I can put in a few thoughts...
Firstly - heat is your friend. You'd be suprised how much a hot air gun (or your Miss's hair dryer) will loosen up mastic or other window/body sealant.
Secondly - and be careful with this - get your wax and grease remover and use it when the mastic/sealant is hot and runny... wipe to your hearts content.
https://www.sau.com.au/forums/topic/327446-rear-qtr-window/#findComment-5328034
I hav just gone through this process taken all my windows out, since i was respraying i just got a grinder with a wire wheel on it and it just tore off really easy...
If your careful enough u should b able use a grinder and keep any marks behind where the window sits, and if ur worried bout it rusting again u could just mask up all the good paint around the window and paint the part underneath it so u shouldnt c a thing. I know it would b a pain to paint just a little bit like that but i couldnt work out any other way to easily remove that stuff, it just sticks soooo well :)
I did hav a go at cutting off the sealant but as u said u would b very likely to scratch some of ur paint...
https://www.sau.com.au/forums/topic/327446-rear-qtr-window/#findComment-5334143
I know it's probably a little late, but what model are we talking here? Most of these guys are talking about removing mastic or butyl sealer, when in fact you are likely dealing with urethane. I know my r33 is urethane.
If you can't just peel it off by hand, it's urethane. And you will have to cut it off, of wire wheel it off. But all models of skyline have encapsulated quarter windows, so just mask it off, dry fit the windows to make sure you won't be putting paint anywhere that won't be covered by the window seal, and spray anywhere the paint is damaged. No blending required, as you won't see the edge anyway. Done. Oh but use a fresh stanley blade if you cut it so you don't slip and put a scratch where it will be visible, and you'll be fine.
Do not try to heat gun it. The paint will bubble long before the urethane will melt, trust me.
https://www.sau.com.au/forums/topic/327446-rear-qtr-window/#findComment-5356795
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
