Hey i have a full alarm fitted to my car but the other day it got broken into, the only thing taken was my morphine tablets which i just picked up from the chemist, i suspect someone was watching the chemist. Anyways they used 2 coat hangers joined together and slipped it in between the side window and the door rubber and it had a hook on the end which they used to catch the door lock from the inside, now that would have been hard to do bec i tried to do it and it took me ages, the alarm went off but it wasnt on for long b4 i got to it so im thinking the ultrasonics didnt work. Im so gutted, out of everything they could have taken from inside the car that was the most precous to me, its going to be almost impossible for the doc to give me more cos there an authority script. Anyone know how ultrasonics work exactly and how they should be possitioned properly so this can never happen again ..
https://www.sau.com.au/forums/topic/327526-ultrasonics/
Well considering it takes all of about 10 seconds for someone with reasonable skill to do that - I'd probably say whoever it was was simply experienced.
Just because you cannot do it that fast, doesn't mean it cannot be done :whistling:
I used to be able to get into an bomb old car of mine, my first car.... who's lock loved playing up... in about 20 seconds.
https://www.sau.com.au/forums/topic/327526-ultrasonics/#findComment-5328421
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
