Have a pair of R33 lower control arms - $150
I put a pair on my last R32 and they are an absolutely great upgrade, great way of getting negative camber without buying adjustable upper arms, with a big difference to steering response and increased lock. Heres how I came across the idea, Thanks Simon-R32: R33 Lower control arms into R32
Also have some other series 1 R33 parts available...
Tein Coilovers, height adjustable - $500
Front seats - $150
Window washer bottle - $50
Complete doors - $350pair or will separate if you need something
R33 speedo - $100 changes
3" Hi-flow stainless steel cat - $100
Quality cat backs 2 to choose: 1 x 3" inch with 2 mufflers - $300
1 x twin drift pipes one muffler in the system - $350
PM or 0401 404 104
+ Postage if your interstate
If you need something else for your R33, please PM as I haven't mentioned everything.
pics of twin tip exhaust
Tried to find a pic of them on the car but no luck. They tucked up nicely to the rear bar and didnt stick out a mile. The exhaust doesn't include the high flow 3" cat if you wanted that as well let me know and I can do a deal.
Edited by Jinman
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
