Hi guy's I picked up an r32 gts-t and it had some dirty old coolant in it. First month i had it the same coolant was left in it and it stayed at the same level. Now i have flushed the system and replaced it with fresh coolant and every couple of days the coolant level in the radiator has gone down and There is no signs of leaking. I have a white sheet under the car to detect leaks. The head gasket is not blown (no milky oil) so it has me stumped. what else could chew coolant or is the coolant I have (repco branded coolant) the problem.
https://www.sau.com.au/forums/topic/327822-vanishing-coolant/
Yeah sounds like the water pump has let go in the seals. This can happen when people flush the coolant due to the fact that you can remove rust and scale that may have built up and stopped it from leaking. Could also be a loose clamp at the water pump maybe
Dunno about the RB20, but on the RB25 there is a welch plug at the front of the motor near the water pump.... Mine was stuffed... I actually thought that it was the water pump and when I did my 100K service, i noticed that it was leaking from the welch plug... gheyness.....
After getting a good quallity torch and taking a look it appears that it is the passenger side of the engine that has the leak. is this consistant with the turbo water lines and if so how much work is involved in replacing them?
Could be any number of things mate......
Best bet is to try to see where it is leaking from..... Check all hoses and connections for wetness for a start..... Try doing it on a sunny day where you get good light, or go to bunnings and get one of those $20 halogen lamps.... Great to work on cars with......
Does it leak when it is hot or cold???? Or both....
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
