isn't the flywheel power calculated by doing the power run and then letting the engine run back down (rather than applying the brakes to slow it down or pushing the clutch in)? this allows it to measure the resistance of the gearbox, etc and then work out the loss. i'm not totally sure, but i thought that this was 1 way of calculating it on a dyno. i know that true engine power can only be found on an engine dyno, but i thought that the calculated power could be worked out, and i am assuming that this is what has been done in this case.
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5337054
in reponse to the original post..
this exact symptom happened to me where the engine effectively "shuts down" for a second very violently and then keeps on driving but you have to stay off the gas to prevent it happening frequently.
in my case it was a coil(s) starting to play up and having a giant misfire. when i upped the boost to 15psi or so, it would suddenly have a violent stall once boost got up there, so i wound back the boost and problem was solved. however in the coming weeks it started having a slight misfire even at low boost and we realised it was coils causing it. the higher the boost, the worse it got.
this may not be your issue, just another possibility. i hadn't experienced rich&retard before but i thought there was no way in hell it would respond as violently as that. it would literally throw you forward and break your nose on the dash if you weren't wearing a seat belt.
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5337438
  • 2 months later...
Hi guys,
Just try'n to look up some info. I would like to run 10-11 psi with a boost T I got ready to install. How high can I actually go before rich and retard kicks in?
Would I need to install and retune with a new ecu chip or get a different air flow meter? What actually causes it and can i get that kind of boost from the stock ecu?
I hear some people talk about an R32 actuator... does that help?
I got only a 3" turbo back exhaust at the moment and getting 8psi. A walbro fuel pump is on the way though.
Still learning...
regards,
Dan
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5466242
Hello there!
As the starter of this thread I have found out that it was not R&R, but fuel cut.
Once the ECU detects a certain load level it shuts down the engine by interrupting ignition and fuel.
Since I have started this thread I got myself Nistune and all is sorted out now.
I know a great deal more now about the ECU and I can recommend Nistune to anyone planning
to increase HP over a certain level.
Cheers ...
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5466452
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
