Hey guys,
I'm nearing to the end of my conversion to turbo.
I need a few parts by Saturday
R33 S1 or S2 speedo manual and low k's!
R33 dump pipe(Stock or aftermarket anything cheap!)
R33 front pipe (Stock or aftermarket anything cheap!)
R33 exhaust (Stock or aftermarket anything cheap!)
Also if anyones free tomorrow for a few hours and knows how to remove an R33 wiring loom and remove rear 5 stud hubs let me know
I have a bottle of red label for anyone who wants to help :)
The dash surrounding has already been removed and the engine plugs have been removed. the dash just needs to be removed and unplugged. Also the rear 5 stud hubs have to be removed (Just the 5 stud hub not the rotors or calipers)!
Cheers
https://www.sau.com.au/forums/topic/328222-help-and-parts-needed-asap/
why you need Speedo just keep yours in and get an aftermarket boost guage
thats true isn't it
but then if i was to change the engine loom over does that still mean i can still run the old speedo off it?
I have an aftermarket 3" front/Dump pipe I will sell you for $100
hope ur engine last's man
cheers chris
speedo looms are the same RB25de det RB26dett across the R33 range
ok. thanks for that at least i know now :yes:
so how does the psi show up on the turbo ones?
cheers chris
ok. thanks for that at least i know now :)
Your boost readings come off the plenum via a little black hose that goes to a little black box in engine bay on drivers side near firewall.
Edited by Shazza24
can come off many parts of the engine
best way is putting a t piece in the front of the plenum near where the fpr line goes
ill pop round on Saturday and help Adrian hook everything up :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
