Hi everyone,
I'm sure this has probably been brought up on here already somewhere but I couldn't find it with a search.
I've been after a carbon bonnet spoiler for my r34 gtt and they seem to be the hardest thing to find but I've come across this one on ebay; http://cgi.ebay.com/Carbon-Fiber-Hood-Add-...=item335c9b855f
Has anyone else brought one of these from this user? Good fit etc???
All help appreciated :yes:
Cheers, James
https://www.sau.com.au/forums/topic/328274-r34-gtt-bonnet-spoiler/
Anyone?????? :D
Hi everyone,
All help appreciated :)
Cheers, James
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
