I was just curious bout the jap language. Is it easy to learn or what? I've decided to go to tafe and always wanted to learn a language and thought japanese would be a good one to learn.
So will it be hard or easy or inbetween i know it would mainly depend on me and weather i will pick it up or not but any help is good.
https://www.sau.com.au/forums/topic/32845-language/
Just remember Ben, it's all dependent on your attitude... if you *really* believe you'll benifit personally by learning Japanese, and you won't be afraid to concienciously make mistakes (because you don't know how to say it exactly in Japanese, but want to express yourself), then you're on the right track. My 2c...
https://www.sau.com.au/forums/topic/32845-language/#findComment-659222
...but Japanese is damn difficult sometimes. Kanji for me is the most challenging. Of course that means reading is difficult too, but when you do learn something useful, it's soooooooo satisfying.
https://www.sau.com.au/forums/topic/32845-language/#findComment-659510
Totally, I am 100% with Rezz. I lived in Japan for a while and learnt Nihongo pretty quickly, but that is because I was tough on myself and only hung out with native Japanese speakers and learnt Kanji everyday. Easy to get in the foreigner groove and loose focus, but when you get it going, it is really awesome to be drinking and having a blast with locals.
Be persistent!!!
my 2c
https://www.sau.com.au/forums/topic/32845-language/#findComment-659742
pricy? im married to a japanese girl and the most weve spent so fay is on my car and a plasma tv.....    the wedding ceremony is heaps but you dont have to have one.
Pricy..I mean not only money..I have been married one for 11 years now, I paid my freedom for that..so..it's pricy.. :Oops:
https://www.sau.com.au/forums/topic/32845-language/#findComment-672532
yep im learning japanese now in yr 11, i love it cause i enjoy it if u dont u've got f**k all chance . its not a nesessity to learn kanji. you can spend a life time learnin it. learn hiragana. 46 basic characters super easy.i also plan to go to japan after hsc so can any body suggest the major cities for car activity, underground and workshop.
https://www.sau.com.au/forums/topic/32845-language/#findComment-689903
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
