Expressions of interest wanted for the purchase of my R32 GTST. it has a potent aspirated LS1 Chevy making just over 300rwkw.
It runs a jim berry custom built single plate ceramic clutch and t56 6 speed tremec gearbox. R32 rear cradle with gtr lsd and one piece tailshaft fitted.
Suspension is bilstein/eibarch coilovers with full adjustable whitlene bush kits and bars.
Brakes are 330mm 8 spot front and 6 spot rear D2 items.
rays daytonas 17x8 & 17x9s with bridgestone RE55s.
Car has had full panel and paint including new rear gtr quarter panels and gtr bonnet.
Full autometer dash, sabelt seat, Sparco wheel, willains 5 point harness, rpm window net.
Car is fully cams logbooked as a 3D sports sedan.
Build quality is excellent, no expense has been spared.
Car has only done about 20hrs track work including last circuit club track day at wakefield park where it ran in the 1.08s
It is a purpose built track car and not road registerable. The full detailed build can be seen on the link below.
Asking price is 35K. Will consider swap for clean standard r32 gtr + cash.
Please Call mobile 0425349923.
serious buyers only, no tyre kickers or test pilots.
Located in Wollongong. Can deliver with in reason.
http://www.skylinesaustralia.com/forums/R3...on-t187852.html
https://www.sau.com.au/forums/topic/328537-r32-ls1-powered-track-car/
  • 5 months later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
