Yeh weve learnt over the last 5 years of in/outs its just easier to disconnect everything and just take motor/gbox out in one hit. Do what you need to do, then chuck it back in!
Comment about your piston choice mate. Your going for higher comps to help response? Weve run both cp's flat top and domes and its makes bugger all difference. What does make the difference is manifold choices. Or so we found when at the track.
On a road car running 9:1 might be well and good, but for 95% of the time whilst on the race track you never fall off boost so much that you would really need that extra comp to help get you back on. Whilst racing you more then likely wont notice the difference. I couldnt.
Yeah i also find all this talk lately about high CR combo's being more responsive etc. is more theory than anything. Ive owned several VL turbo's both standard and hi-comp conversions with neither being superior than the other unless camshaft profiles and manifolding differences were brought into play. The bore and stroke still stay the same so swept volume doesnt change just the space its compressed into. The engine has to work slightly more to compress the mixture and does receive a slightly larger increase in velocity when exiting the exhaust port. If the supporting hardware is not inplace to support this small increase its lost before it reaches the turbine housing. This small advantage is negated as soon as boost comes into play as the air is forced into the cylinder not drawn in under vacuum. Id rather search for a little headroom in CR so on a hot day if tunes a little off or fuel quality is down the engine doesn't get a hard time. Id say driving an identical car with an 8.0:1 or a 9.0:1 the seat of the pants dyno would be hard pressed to tell any difference and in some cases would actually think the low CR car is the high CR if the placebo effect was introduced.
Edited by Supa Steve
you cant lower CR to allow for a bad tune. if theres too much timing it'll knock regardless. the only solution for that is to get it tuned properly
under light load with the same timing map a higher CR motor will be more responsive
point taken. i have done a lot of research and talking to people over past week including people who have rb30det with lower CR and i feel that staying close to the 9:1 ratio will suit my application. i guess time will soon tell. so you have played around with a few different exhaust manifolds to get the correct result?
I didnt mean to be negative about your choice if it came across that way. Just wanted to share my exp with the matter. It maybe me, but on the track I couldnt tell the difference. The other possible issue is if you run bigger cams with more lift, you just need to be aware of your piston to valve clearance. We had the 9:1 CPs,1.2mm HG and 10.2mm lift and we were around .120" or slightly less.
We went from a gcg china exhaust manifold that cracked after every second race meet to a 6boost mani and we picked up something like 300rpm spool and made more power on the same boost. But we also tried greddy inlet manifold and currently have a plasmaman and we picked up abit of down low power from the that switch. It was the manifold changes that I felt made the most difference, atleast on the dyno and on the track in comparison to the slightly higher CR. Lol at the moment we are just about to switch over to a gtr inlet/throttle bodies. So we will be able to see what difference that may make too.
But everyone is different, you or others may notice things I dont or cant. When your done and out racing you will be able to see for yourself. At the end of the day so long as you make the power you want and you get the response your chasing thats all that counts. Doesnt really matter how you get it! Hopefully it will be enough to help you win!
you didnt come accross negative at all r33_racer. All the input i can get is very helpful. Ive only owned imports as street cars previously and much of my racing experience is go karts and a couple of track days.
Your right in suggesting that it doesnt matter how i get my power as long as i get it. Many suggested running lower cr and that way allows more room for timing and more boost.
But on the same note just as many people say stay at around the 9:1 mark because im not planning on heading past about 17 psi and not planning on dialing a pile of timing into it.
engine is partway through the build. gone with the aries 10cc dome top. at 0 deck with 1.2 head gasket they should give close enough to 9:1 which i what ive been trying to stay close to through my research and build.
james_03 did u nip 0.8 off the deck because it needed it (ie. the face was damaged) or simply to lift ur CR ?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
