For sale is my ecr33 r200 kaaz 2 way, part number san 2645 4.3:1 ratio, i have removed cover for photos and inspection, still has kaaz oil inside, ready to bolt up, almost new condition, done very little work, approx 5-10k.
using a nismo 1.5 way now for circuit
price is set at $850 firm
sydney pickup only
please call or text 0424 364 610
if i dont answer just leave a message or a text
https://www.sau.com.au/forums/topic/328902-kaaz-2way-for-r33gtst-cheap/
hey mate, i think they might be, if you live in sydney i will happily have a look under your car and will tell you if it fits.
cheers
nah sorry man im in s.a
im very interested to know ive tried to do some searching but come up with nothing.
can you give me a little more back ground on it, what it was used in/for?
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
