Hey guys,
I'm wrecking a R34 Skyline
- 4 door sedan
- KR4 silver
- Auto / RB20de
Am located in Auckland, NZ. Shipping is around $15 AU to your doorstep for most items
PM me only, regarding any parts. Keep my thread clean
Exterior
Bonnet catch + cable $80
R34 wing mirrors (KR4 silver) $250
Rear wiper motor + arm $80
Xenon headlights (normal bulbs) $800 delivered
Electrics + misc
Airbag module / computer $150
Aircon pump / compressor $80
RB20de NEO wiring loom + ECU (same as RB25de NEO) missing injector + coil loom $150
Interior
B pillar trim (upper) $60
B pillar trim (lower) $60
C pillar trim $60
CD brackets + surround $80
Drivers side fuse cover $80
Drivers foot fuse cover $80
Dash cluster surround $40
Dash cluster Tiptronic GT-25 (approx 120,000 ks) $80
ECU cover $80
Factory CD player (Cassette player mouth broken) $40
Factory TV / Navigation cover $80
Front door speaker holders $40
Glove box $80
Interior handle surround $60
Interior seats belts + buckles (All 5, inc bolts) $200
Interior carpet $140
Left / Right dash vents $80
R34 head rests (GTT) $60
R34 head rests (N/A) $60
Roof lining lights + handles $50
Rubber seals (doors) $40
Steering wheel Tiptronic (no air bag, few marks) $40
Edited by Chang
https://www.sau.com.au/forums/topic/329003-fs-wrecking-complete-r34-skyline/
SOLD items:
A Pillar trim
Aircon controller
Air flow meter (AFM)
Air box + filter
Bonnet badge
Boot trim / space saver / tool kit
Cam angle sensor (CAS)
Centre air vent + hazard switch
Centre console (leather compartment)
Coil packs + coil loom
Floor mats
Front / rear seats
Gear surround + ash tray
Headlights
Master window switch
Rear door cards
Stereo brackets + surround
Sump gaurd
Washer bottle
Edited by Chang
  • 2 months later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
