R32 10 point roll cage. bolt in. safety 21 brand. $950
blitz 100mm GTR cooler. $400
Selbys front and rear adjustable GTR swaybars. $400 pair
JIC silver coilovers suit GTR/GTS4 R32. $500
HKS triple plate clutch. Suit RB. $1200
ARC castor rods, suit GTR/GTS4 $150
R32 GTR tail lights. $50 a side
R32 GTR Vspec bootlip $100
Genuine bride fixed back black, Good condition. with S13/14/15 rail. $650
Panasport 5 spoke wheels. 17x9 +20 all round. black centre polished dish. $1200
Rays Eng. Forged 1 piece 5 spoke Gram lights. 17x9.5 +22 all round. $2200
S15 motor, complete inc loom, ecu, coilpacks etc. 79,000km $2800
S15 6 speed transmission, comes with tailshaft, shifter. 79,000km $1200
S15 5 stud conversion kit. front and rear brakes and hubs, incl front LCA's $1100
S15 TRIAL front bar, painted gloss white. $200
S15 climate control unit. $100
S14/S15 Greddy intercooler kit. $350
SR alloy radiator. $200
RB alloy radiator. $200
JUN RB26 cams. 260in 270ex 9.25 lift. Tomei adjustable cam gears x2 $900
S15 rear cradle. $350 incl stock arms and knuckles.
KKR 430 turbo, good condition, no shaft play. comes with dump pipe. bolt on RB20/25 turbo. $400
Front R32 strut brace $80
Contact: Buckna 0427282562
https://www.sau.com.au/forums/topic/329046-big-garage-sale/
radiator is a aftermarket alloy item. no brandings, looks to be a china item, same as the JJR ones.
will get pics of both soon.
DMIN8R - will not part gears from cams. :P
https://www.sau.com.au/forums/topic/329046-big-garage-sale/#findComment-5348873
these are the front pair, the rears have slightly bigger dish, but less brake clearance :) good condition all round.
cams do not have a part number listed on them, just size. 260 9.25 on one, 270 9.25 on the other.
They came from a gtr with stock valves, springs, lifters. So they are a drop in cam for RB26.
https://www.sau.com.au/forums/topic/329046-big-garage-sale/#findComment-5350484
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
