VN's are awesome, one of the best as strange as it may sound. they can be had for nothing (literally, i got a clean one for free) good strong diff suitable for welding, again free (welded it up myself) and they will cop a hiding all day without a drama.
too many people get caught up chasing a number when buying/modifying their car, and they forget its all about having fun. VN with welded diff is one of the most fun things i have ever come across, automotive or other
Personally I dont have a welded diff, but they can be great fun, good power to weight ratio for such a cheap car of nearly 100kw per ton. I got a VP wagon and if I give it the beans it always brings a smile to my face. Also its all about how cheap parts are for it, for instance the voltage regulator in my alternator was dying (the original regulator from the factory 18 years and 340,000kms later), $33 and 30 minutes later it was fixed good as new. I've seen a fair few supercharged/Turbo Buick's and Ecotec's in Zoom and Boost and they are cranking out some serious power quite reliably too.
Japanese engineering is brilliant dont get me wrong but those engines are designed to be perfect and treated with the upmost respect by the driver, not to be driven by hoons bouncing off rev limiter. American/Australian engineered engines are designed to be idiot proof so you thrash them around all day and they will be fine with little to no maintainance.
Edited by FrangaR33
Man if you are serious about anything like that you should look at performance forums, guys doing that stuff all day long. my boss is putting a VH45 into a VH commodore, and it gets better the size of the turbo he is then gonna add to it, is huge bigger then alot of turbos that i have seen on even the majority of 2J's.
I say if you have the time and persistence then go for it.
Good to see people thinking out side the box. Even if i personally thinks commodores are crap and RB's rule. i didn't check where you where from but if you can make it to Noosa you should see the guys at AM Auto they do a lot of custom work like this, most people on this forums have most likely seen there work even if you don't know it
Hey there,
Im looking for some advice. I have a VS Commodore which i no longer drive anymore and im looking seriously at putting an RB26DETT into it. For the time being i would want it to be pretty close to stock with a manual gearbox. My main questions are:
1. What will i need other than a front cut?
2. I have seen an RB25 in VS, is there much difference?
3. Who would be a reputable workshop to do this type of work?
Thanks for your help.
im guessing its for drags.
go 2jz. stroke it.
Friend put a rb25 into his vs many moons ago. It was a good car and the conversion isnt that difficult. Your talking vl crossmember custom gearbox crossmember and a new tail shaft for the mechanical side. Hydraulic clutch for hydraulic side. Wiring and piping. However when he was finished he was left with basically a r33 gtst. (performance wise) So maybe its not worth it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
