Gday guys,
Have a mate at work that is selling a set of cusco zero 1 coilovers they are good condition, no knocks or leaks.
To suit a R33 skyline. He is asking $900 for the set.
Please contact the person below as i dont know anything about them.
Located in the Adelaide hills SA
Contact Chris on 0420986545
Im selling some of my stuff that is around my place to get my coupe back on the road.
Z32 AFM $250. Good condition mesh isnt bent or damaged.
Early model HR31 S3 GTS grille. Good condition a little plastic polish and it would come up mint. $200
Later model HR31 S3 GTS grille. Same as above. $250
S2 HR31 grille. Good condition. $140
DBA slotted front rotors. Seen less than 15000k. Reason for sale is because i have r33 brakes $200 firm.
R33 engine mounts good condition no cracks. Make an offer
R33 stock dump. Make an offer
RB20 fan blade with viscus - $50. Good condition no cracks etc.
Also have a stock HR31 fuel pump don't know if they are different to Aussie 31's. $30
Stock front and rear swaybars for a HR31. $50 for both
More parts to come in the next few weeks so stay tuned.
All parts are located in the Adelaide hills.
Pics will be up soon.
Pm me or contact me on 0420491344. I work during the day so message would be best.
Adam
Added 16/8
2 x s3 rear garnishes.
One comes with a s3 rear garnish, rear number plate lights, boot strip and a set or hotplate taillights in good condition. Chasing $300 firm
other one comes with number plate lights and rear garnish. $200 firm.
TI s3 grill. Good condition chrome isnt cracked. $100
Adam
Edited by KDS_HR31
Bump
Got two sets of rear r32 gtst disks, calipers, pads and lines. Both have 80% meat left on every pad, all the disks arent warped or lipped, and calipes dont have split piston seals.
Looking for $300 each set.
Pics soon
  • 3 weeks later...
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
