Ok this might seem really stupid to many people but im at a loss. i might not also be able to explain myself to well but ill give it a shot. Well I have seen a few images of r34 gtt's where the hood isn't as long and doesn't sit down as far.
For example
as pictured both the hood and the front bumper sit higher, the hood isn't as long as a stock r34 gtt. The bumper seems to sit up a bit higher and sits inline with the top of the headlights.
where as my stock skyline which i plan to modify bumper sits about the mid point of the headlights like this
as pictured i was wondering how exactly to rise the bumper and make the hood shorter. i obviously know that i need a new bumper and i am having an entire body kit custom made but how can it be configured so that the hood isn't as long, is it don't by cutting off some of the hood or simply installing a bigger bumper and having it sit on that? it seems to have an extra lip or somthing and i need to know how to have it removed.
sorry if this is a bit confusing but its just something i need to work out to modify my car and i need to get started straight away.
https://www.sau.com.au/forums/topic/330293-question-about-body/
yeah man thats the point of why i want to do it, i like the look much better, but they are definitely gtts, the first one is a veilside kit and the second is a gtr conversion kit but that still doesnt explain how the hood sits flush with the top of the headlights and the front bar is higher
possible reasons Why yours is different
1 - both example pictures are GTR's and yours is GTT
2 - both examples are aftermarket carbon items and yours is stock
3 - both examples have aftermarket front bars where as yours is stock
In my opinion, don't try to modify your bumper and bonnet too look like that... buy aftermarket gear to get the same result
Im fairly certain GTT bonnets & GTR bonnets are 2 different size, weights and style bonnets
but correct me if i'm wrong.
cheers
i am 100% sure they are both gtts because they are advertised as that by private sellers:) and i know that mine is stock and that is what i want to change, my concern is how exactly to change it to raise the bumper and cut back the hood because i could go buy a new gtt bumper but it will still sit lower than these and im pretty sure a gtr bumper wont fit to it
Most stuff of the same model is interchangeable
cant say for sure about 34s but for 33s you can interchange guards, bonnets, lights etc etc without any mods
The guards on that Green 34 look to pumped to be a GTT
unless his done a really good full conversion
Edited by 89CAL
no your right to put a GTR bonnet on GTT you will need the GTR hinges, latch , and probably a GTR style front bar so you dont have a gap in between the GTR bonnet and stock GTT bar
but the reason for them looking different is coz they are 2 different types of cars. like you said one has a GTR conversion
and the other a complete kit you wont be able to get your car to look the same without changing your bonnet and bar
im not having someone fabricate the bonnet im just getting a custom front bumper!
could someone show me a site or somewhere i could buy a ztune bonnet that would fit the way i want
or just a standard gtr bonnet that will fit the way i want
http://www.musecret.com.au/prod1317.htm
Then call the local wreckers and see if they have any GTR bonnet latches and hinges floating around. If you do end up getting a front bar that was intended to go with a GTT, you can get something like this to fill in the gap the GTR bonnet makes:
http://www.hybridcustoms.com.au/Images/Pro...Bonnet_Clip.jpg
bro seriously just do the gtr conversion at the fron, then go an aftermarket front bumper for a gtr, get gtr z tune guards and bonnet, if u go a carbon bonnet u dont need to change the latch if u go pins just remove the latch assembly (this is what i have done) but u might get pulled over a lil bit lol.
hahahahahahaha
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
