Hi All,
This may seem like a totally dense question but does anyone know where I can purchase some shims for rb26 head. Did a google search for businesses but nothing local or close to local (SE Melb).
I need shims with this thickness below:
  • 2.80mm
  • 2.73mm
  • 2.70mm
  • 2.99mm
  • 2.95mm
  • 3.00mm
  • 2.97mm
  • 3.03mm
  • 2.99mm
Hope someone can help point me in the right direction.
Thanking everyone in advanced.
https://www.sau.com.au/forums/topic/330645-where-can-you-buy-shims/
Your gonna love the price form nissan, plus they are case hardened to .02mm and can't be ground down at all. Call precision shims australia (precisionshims.com.au) 03 9723 0199 as he has shims ready to go, in increments of .02 and case hardened to .2mm so you can rub them back to required tolerance- if my memory srerves me correctly- if you call he'll sort you out for info. Plus they're a much more realistic price.
Edited by doo doo
x2
good bloke to deal with
you saying they cant be ground down or shouldnt be ground down?
we ground some of my SR20 shims and guides when i converted to solid lifters, thought they would be the same
Stock ones shouldn't be ground down, you take away the .02mm hardened layer (at least this is for RB shims, which are direct bucket and shim actuation) My stock shims on the RB had mushrooming after about 120,000 kays. You would have to check with someone about the SR having the different valve actuation design, different shims.
Thanks for the help everyone!
doo doo you are an absolute life saver you have saved my skin on many occasions much appreciated bud. I'll have to shout you a beer if/when you come down this way.
  • 1 month later...
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
