hey, like the description says: ive got a 03 wrx that i wanna use as trade or trade plus cash ur way for a nice r33/r34 GTR. (pref r34)
http://www.boostcruising.com/forums/index....howtopic=583113 if u wanna check out my car.
any questions just pm me or txt me 0433812776
https://www.sau.com.au/forums/topic/330741-wtb-gtr-r33r34/
What is your budget on top of your WRX mate? (I'm assuming you have a budget, lucky bugger if you don't! lol)
hey, i have a budget and i'm willing to stretch it for the right 1. But if u talking bout a budget to buy ur car yeah...... 90K is way to much but thanx for the offer n good luck with the sale.
https://www.sau.com.au/forums/topic/330741-wtb-gtr-r33r34/#findComment-5375560
lol, who mentioned anything about 90k? LOL
sorry mate i clicked into ur topics n seen ur GTR for sale was 95 now 88k n i thought u were asking if i was interested in that lol. all good mate
https://www.sau.com.au/forums/topic/330741-wtb-gtr-r33r34/#findComment-5376580
  • 4 weeks later...
Hey mate where abouts are you located?
I might be interested in a swap plus a little money.
I've got a R33 very very clean car
Let me know if your interested. My number is 0400443880
I'm in Adelaide.
Cheers peter
https://www.sau.com.au/forums/topic/330741-wtb-gtr-r33r34/#findComment-5451377
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
