i dont get how this SMG works is it just tiptronic like in any other car or? why is it bad? does the car actually get off the throttle when you change up/down gears?
havent really looked into them im just avoiding them based on what i've read so far. i actually like the idea of a sequential box where its the same as manual just without a clutch pedal but if its bad and has problems etc then i'll stick to the 6sp
My good friend used to own a 1998 E36 M3 Anniversary edition convertible. Was the 3.2L 6 etc.....all it had was a cat back exhaust and it was making 258hp @ the rear wheels. That pulled a low low 13....
If you are really only going to consider an "M" BMW, then go for an E39 M5, power, luxury, style, everything :)
i love all m5s but even the e39 is out of my price range :P but i'll keep a look out for a super good deal, you never know...
  • Replies 54
Exactly as it should be. Think of riding a motorbike.
The SMG's are also expensive to fix, and will need a full overhaul by now if not already done.
agreed its the way it should be, my old r34 auto had tiptronic and to go up gears you push forward and it felt so wrong and not natural.
The SMG boxes is a manual gearbox with a normal manual clutch and all that the only difference is that the clutch is engaged and disengaged by electronics and a hydraulic pump.
here is a clip of the SMG box in action with the gear speed turned almost all the way up:
and another using the launch control that these gearboxes have:
^They are E46's. Much improved over E36s.
shit, thats my bad i was talking about e46's and you guys were talking about e36's. sorry about that.
And yes the SMG in the e36's isnt very good. it was greatly improved in the e46's which was the one i test drove. cant really say how the smg is in the e36's as i never test drove one so im only going by what ive been reading which is they are not very good at all.
on another note is it true that the e36 m3's have the same gearbox as the r34 gtr or is it the e46 m3's that have the same as the r34 gtr?
i seeeeeeeee
guess only way to see is to get test drives in both manual and smg and see what suits me best
aargh really want to call up some ads on carsales and organise test drives but i'd feel like a user as i cant actually buy the car till mine is sold lol
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
