http://www.horsepowerinabox.com/HPIAB2/prod641.htm
I might order one of these tomorow what yas think of price and size I don't care about lag
Do not buy that one.
If you are going down the route of a GT3076 then you will need a T3 flanged (not T25 SR20 type exhaust flange).
I would sit down and have a really good think about what you want out of a turbo before acting as you will save money in the long run by thinking it through.
I am not a fan of the turbine housings that bolt up to the stock dumps as I have never seen them allow the full potential of a 76mm compressor.
If you go down the path of a complete Garrett unit then you need to consider dump, oil/water lines, intake changes and you will need new injectors even with the correct HPIAB GT3076 with T3 flange there are still issues with oil/water line and intake changes.
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5379999
If you're thinking of that exact one in the link, then don't do it. It's in a T25 flange and is made to fit SR engines.
Look for one that is in T3 flange :D
Edit: Dammit, beaten :)
Edited by d1_drifter
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380002
i no its not that one i need but morrie at from that place says he has the one for rbs and the oil n water lines arnt much of a hassle. and im doin the exuast to suit so that doesnt matter.
i was gona get him to fit it so he can deal with it but now i have the motor striped down i was gona do it myself and just give it to him to tune.
i want to spend about $1600 to $1800max just on turbo.
if yas wana thro ya sugestions down go for it. just remember lag doesnt bother me, so must be in the 30s
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380071
cars got 200wkw now with fmic pod no rear muffler and nistune set at 14 psi (droping to 9)
want to get 250wkw with
new turbo $1600
fuel pump $150
afm $200
exhaust$800
if injectors can handle it il do them later and what ever else to get 300wkw
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380105
Ild be happy with 270 to 280 if that's about all that turbo can make I'm just Gona run it at what Eva the injectors can handle for now untill I get more coin. The exhaust and other bits are Gina send me broke for a while
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380898
Trying to pay mortgage on one wage at moment so budget isn't looking good for injectors.
Has anyone got sum of that metal paste stuff I can steal so I don't have to buy a $50 tin of it?
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5381030
You won't need the afm if you don't change the injectors. Save the money for your turbo - total installation costs will be more with bits and pieces. Also I think fuel pump will cost more than $150 and afm will be $300.
Just do the turbo and fuel pump for now. What are you using for boost control?
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5381108
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
