Plans have started for JDM fest 2010, It will bigger and Better than last year, keep an eye out for any information at
http://ultim8racing.blogspot.com/
With just over a month till JDM Fest 2010 things are picking up pace. Trophies up for grabs are:
King of JDM Fest
People Choice
Best Stereo
Best Paint
Best Engine Bay
Dyno Dominator
Most Powerful AWD
Most Powerful FWD
Most Powerful RWD
BDL Car Stereo will be joining us this year with an awesome display. Things are really hotting up.
If any car clubs are coming and would like to be together please let us know so we can set up an area for you.
Stay tuned for more info.
https://www.sau.com.au/forums/topic/331393-jdm-fest-2010/
  • Replies 123
That could have been just before he called me... :D
I never knew this was on until I had a bit of a surf around, I've put this up on a couple of other forums that I check out and was quite suprised to see that zero advertising has been made for this event. It's a top idea, but will only get better if the organisers spend a short time actually advertising it
https://www.sau.com.au/forums/topic/331393-jdm-fest-2010/#findComment-5383272
Point taken, have been working on it, but dont have access to all the forums, so far we have posted it on 9 forums.
It will be a good event, should be a few trade stands up this year, and with Glen out here and Fast 4s coming down for it, should be a good day
https://www.sau.com.au/forums/topic/331393-jdm-fest-2010/#findComment-5383283
