Looking for a bit of a change - keen as for an older GT-R, S15, WRX, EVO 5-7, FD3S Rx-7
The vehicle up for grabs (if anyone is interested...) Is a 1998 R34 GT-T
121 xxx kms
Manual
Exedy Single Plate Clutch
HKS Return Flow front mount
Trust Exhaust
HKS EVC-S (uninstalled)
Apexi Pod (uninstalled, stock airbox on presently)
Lowered King Springs
Whiteline Rear Swaybar
Apexi Turbo timer (uninstalled)
Spoiler removed, still have it in the garage
Plus all the usual DVD player, Alpine Speakers etc...the 'doof doof' that the previous owner installed :)
Just put some DTM rush wheels on it (bought them off another SAU buyer lol), decent tread front and back, +29 8.5F, +25 9.5R
Also have stockies with decent tread. Pretty keen to keep the DTM's, but i know alot of you have more than a couple of sets of wheels kicking around that are much better quality than my $1K dtm's lol :/
Just transferred it into SA from ACT plates - got thru easy as so interstate swaps is a green light too - as long as your vehicle is REASONABLY STANDARD
Peace
boost controller and pod back on - made a trick little airbox for it on the weekend! Any takers? car is getting a tune up next week - should net around 200killerwasps
Interested in a 180SX (type X front and rear bars/lights) with 2 pages of mods? Amongst the many things it has a fresh rebuilt engine done less than 15000km and makes 267.5rwkw and street driven not track driven.
Edited by slippylotion
Send me the details at [email protected]!
last time i got milk from goat i also got a visit from the RSPCA they told me the goat was a male and it wasnt milk that i had, its still good tho :P
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
