yo your inbox is full,......
anyway...
what do u guyz think of this I'm getting a boomerang installed this Saturday for $1150 @ Jetspeed Melbourne and includez windowz auto up and auto start....
Then I found this
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...&item=956222415
PLZ NOONE BID THIS.....rekon it'z better to get this then get Jetspeedz one?
then this came up
http://www.asiapacific.com.my/xinhai/product07.html
for $400.......but gotta wait for 3-5 weekz though
opinionz plzzzzzz.........
I dont know how the second one says "actual Size"...when it depens on what res you got on your pc..hehehe its damn big if you got it on 640x480~ hehe
Nah seriously, i'd go the boomerang. Ive got friends that have them, they are good. Only thing i dont like about it, is you got the cables hanging everywhere cuase the sensor has to be some where open...it looks bad...see how you go.
was it done @ Jetspeed?
Yeah its in a friends car, holden astra, plates - DIGDIS
Jetspeed made the kit and fited the alarm...
cables for the sensor visible, but thats how its spose to be or it wont work properly. I aint knockin jetspeed, they are good.
The Benxon alarm looks like a pretty much copy of the Boomerang.
It has 5 buttons though, must mean easier access to options,
where as the boomerang, there are only 3 buttons hence you
must press them a multitude of times to get to the same feature.
Am i just going around in circles?
The Boomerang overall is a pretty niffy peice of hardware i must
admit. It does have the amplifier box which usually is clipped
to those glare flap things which I think is what OOHSAM was
refering to. It's only one cable about 5mm thick and goes behind
your pillar cover. I'd be suprised if the Benxon alarm didn't have
something simular.
The Boomerangs distance can be shorten drastically by concrete
buildings or buildings in general. This has been tried and proven.
I've seen alarms that state the same figures as the Boomerang
but work no where near as good.
I'm not saying the Boomerang is the best alarm, I know there
are better ones out there but for the functionabilty wise vs others
I've seen and trialed it is still ahead. The cost is the only
drawback. I've only tested the Boomerang so I can't comment on
the other one. Wether you choose to wait or spend more is up to
you.
Just thought i'd put my 2 cents worth with my experiences.
  • 1 month later...
Not wanting to rain on the parade guys but I dont think its a good move to discuss what alarms you all have/are buying especially where you have mentioned the rego of the vehicle concerned on this forum.
Just a thought
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
