I have for sale a RB26DETT Forged Short Motor
Built for big boost and HP by RB specialist Stuart Jones of Cavehill Enignes
NEW
JE custom forged pistons , with contact reduction and double forced gudgeon oiling
Tomei "H" forged conrods , with upgraded ARP 2000 12 point 8740 chrome moly 220000psi bolts
Perfect Seal race set piston rings with gapless 2n/d rings
ACL Race heat treated main and big end bearings
ARP main studs , ARP headstuds
Nissan N1 oil pump
Tomei 1.5mm oil restrictor
NSK timing belt tensioner , NSK timing belt idler
KP gasket set with multi layer steel head gasket (MLS)
Block
Acid dipped , magnaflux cracktested , cylinder bores sonic test for wall thickness ( X-rayed ) ,
Bored .5mm and diamond plateau honed , Decked square to main tunnel
Crankshaft ( late 32 or 33 with long oil pump drive )
Acid dipped , electromax cracktested , measured , linished ( micro polished ) and fully balanced
Engine is assembled to short motor with sump fitted
c/w secondhand
GTR sump complete with 4.111 diff ratio
alloy engine mount brackets , p/s and a/c mounting brackets , oil filter housing , oil cooler and water pipes ,
thermostate housing , harmonic balancer
All it needs is a cylinder head , water pump and a timing belt
Price $ 8800
May trade or swap for BNR32 GTR
Can email or SMS photo's
PM , call or text
0407807195 Stu
hey mate
to get all the testing n maching done to your block
how much did it cost roughly
what are the pros of getting ur block acid dipped, magnaflux cracktested ?
Some more pic's
ARP head std kit , Adjustable cam gears
Oil filter housing , cooler assembly
Harmonic balancer , p/s bkt , a/c bkt , engine mount bkt's
Exhaust manifolds
I have had a few PM's about the custom pistons
Contact Reduction Grooves: The purpose of machining these grooves is to reduce the amount of contact area
against the cylinder wall when the piston “rocks over”. Contact reduction also serves to disrupt the flame travel into
the crevice area thus helping to reduce detonation.
Double Pin Oilers: Double Pin Oilers deliver twice the amount of oil to the wrist pin as compared to the standard single pin oiler.
8800. thats abit high dont ya think
considering its a standard block with a n1 oil pump :-S
NEW
JE forged pistons , custom ordered with contact reduction grooves and double forced gudgeon oiling
Tomei "H" beam SNCM439 metal forged conrods
ARP 2000 12 point 8740 chrome moly 220000psi conrod bolts
ACL Race heat treated main bearings
ACL Race heat treated big end bearings
ARP main studs
ARP head studs
Nissan N1 oil pump
Alloy adjustable cam gears
Add up all these new parts then see if $ 8800 is too high , then add machining costs
Cash talks and im open to offers
Cheers
did ur machining cost 3 grand did it
NEW
$ 3300 JE forged pistons , custom ordered with contact reduction grooves and double forced gudgeon oiling ( purchased Feb/2009 when $1 aud bought .64 cents us)
$ 1544 Tomei "H" beam SNCM439 metal forged conrods
$ 350 ARP 2000 12 point 8740 chrome moly 220000psi conrod bolts
$ 550 Perfect Seal race set piston rings with gapless 2n/d rings
$ 165 ACL Race heat treated main bearings
$ 95 ACL Race heat treated big end bearings
$ 257 ARP main studs
$ 460 ARP head studs
$ 535 Nissan N1 oil pump
$ 22 Tomei 1.5mm oil restrictor
$ 95 NSK timing belt tensioner
$ 115 NSK timing belt idler
$ 550 KP gasket set with multi layer steel head gasket (MLS)
$ 130 Alloy adjustable cam gears
USED
$ 1300 R33 , Late R32 RB26DETT sub assembly suit reco inc diff assembly ( purchased in 2008 )
Just to give you an idea on prices
Cheers
You interested or just wasting his time? :S
no hes not intrested.
His motor is worth 4 to 5 times what this guy is asking !
Thanks Guy's , for your positive inputs
Cheers STU
THE DO'S AND DONT'S OF THE SAU CLASSIFIEDS!
2. No price debates - put simply if you do not agree with the price being asked, do not comment on the thread. If you believe the seller is asking too much then either pm the thread starter or dont buy the items advertised - simple.
There is to be no "My cousin can get it for much less" or "Your asking too much" comments
have u ever built an motor? i got mine back from the machine shop yesterday with a bill of near 3k just for machining/labour..
its also the time and effort to aquire the parts, big fkn headache can take months etc
Edited by Char
too right!!!
dont even start with trying to enplane the headache!
  • 4 weeks later...
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
