I've heard nothing but praise for BC coilovers and am almost ready to buy a set but thought I would check prices of coilovers from Japan
BC coilovers are $1300 delivered but I've also be quoted on these
Tein Super Streets $1650 (6-9 week delivery)
Greddy Type S - $1670 (6-9 week delivery)
Not sure which way to go as I would prefer something sooner than 6-9 weeks but also want a good product.
Any recommendations?
https://www.sau.com.au/forums/topic/333226-which-coilover/
Hey mate I posted the same question a week ago and yeah everyone seems to love bc's but there are others that say you get what you pay for. As for my descision on which I'm going to go with the greddy type s as I would rather the peace of mind knowing that I have a good quality product
https://www.sau.com.au/forums/topic/333226-which-coilover/#findComment-5402763
I thought ISC coilovers were in the same basket as G4,D2 etc and not very good?
Just my perception mind you not an attempt to stir things up
Can I have more info on how these compare to BC coilovers?
Edited by R34
https://www.sau.com.au/forums/topic/333226-which-coilover/#findComment-5404908
+1 for BC's
I'd put the BC's up against the Tein SS or Greddy type S any day... I've heard plenty of horror stories about both esp the Tein SS.
Just because a product comes from a big brand name it doesn't automatically make it a great product these are very much "entry level" items and they are not tuned for local conditions - remember google is your friend!
Good luck
Edited by Checkbuzz
https://www.sau.com.au/forums/topic/333226-which-coilover/#findComment-5413938
Definetly not in the same league mate. G4 and D2 are generic. ISC is made by ISC. Alot of the design work is also done in Australia along with the new Australian made thrust kit. Our coilovers are also valved to suit different spring rates unlike alot of others out there in the same price bracket. The ISC N1 coilovers have been used in winning DA (national series drift) cars along with the 180sx on the tv show Blood Sweat and Gears being awarded best handling car and the list go's on. If you need any information on the coilovers please send me an email at [email protected] or give me a call on 0413804117.
https://www.sau.com.au/forums/topic/333226-which-coilover/#findComment-5414085
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
