Umm i think we can safely say theres not a car currently in production on the planet (except maybe Skoda) that are still using carbies. Your mates are clearly from the V8 dinosaur set. Even most V8 guys realise fuel injection is the way to go nowadays.
As you may or may not be aware theres two types of fuel delivery systems, one primitive (carburettors) and one modern (fuel injection).
Red17
Kinda offtopic, but why do brand new motorbikes still use carbies? Surely it can't add much more to the price to chuck an ECU in there. I remember being amazed that my 94 CC Lancer used one, but then I found out that 2003 model Kawasaki 250cc bikes are using them!
ah ok, so then I suppose if they slide (which I take to mean they adjust themselves and aren't locked for efficiency at a single point), then they would be almost as efficient as EFI as they aren't just set to be optimal at a particular rev point. Am I totally off? I've got no knowledge of pre EFI tech at all really :D
I can't think of any current model sportsbike that hasn't swapped over to fuel injection. The Yamaha R6 and R1 were 2 of the last to change over.
The difference on bikes with carbs and injectors is not that great. You can get virtually as much power out of flatside carbs on a bike as fuel injection, you will just suffer a tiny bit of response and economy. Even though it is cheap to put an ECU and injectors in, carbs were still generally cheaper (until recently at least). The main reason why Yamaha finally made the move is because everyone else did it, and was therefore a marketing ploy rather than a performance one.
The biggest problem with carbs on bikes is tuning the buggers.
Edit: Many Jap "cruiser" type bikes still use carbs, but this is more to do with the "image" of trying to look like a Harley. Again, marketing.
Majority of new bikes use injection, any that don't is cos its more cost affective.
I was only out at the track a few weeks back and there was a 1600 running an SR20DE with twin sideys (personally i would have gone quad throttle bodys if anything).
and i am sure some of u guys have seen the S14 drag car running an L31(stroked L28) with twin turbos and triple webbers? that thing as mad!!
could someone verify for me if it was running methonol? and possibly nitrous?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
