Does anyone else in Melb have the 60th Anniversary Edition 32?
I'm in the process of making a very detailed skyline guide including all models, specs, options and special editions.
I've started collecting catalogues...
so far I have
1989 R32 (2 + 4 Door + GTR)
1993 R32 (2 + 4 Door)
R32 VS 1 & 2
R33 S1
R33 S2
R33 GTR
R34 GTt
R34 GTV
R34 GTR
R34 GTR Nur
Nismo R33 GTSt
Any more will be greatly appreciated
  • Replies 59
as for the GTSt RM Spec:
It was a GTS-t Type M which was available for 3 months in a limited sale at Nissan/Prince Saitama in 1993.
It included:
Aluminum bonnet
GT-R type front grill
GT-R type rear spoiler
Red SKYLINE Sticker
R Badge
Full sports bodykit and the gtr bumper as an option
Gold GT badge
Only available in 3 limited colours: black, silver, and white.
Images:
oh yeah, there was also a Type M and a Type J 60th anniversary edition, but I dun have any documentation on em cept for this:
An R32 GTS-t limited vehicle.
It was released as a 60th anniversary vehicle of the Nissan foundation.
Commemorative keys
upgraded interior & trim
fog lamp embedded into bumper
as rear spoiler with high mount brake lamp
GT-R rims on M Spec
i have the key but when my car got here it had the badges removed :D
has the upgraded interior too... well had... until i ripped the drivers seat out and to pieces rofl
hmmmm GTR wheels? how do u know if they are GTR wheels?
probably been taken off mine and replaced with normal GTST rims :D
not that i care anymore seeing as they arent even on the car anymore lol
some enkei 6 spokes... no idea what theyre called... theyre the same as the ones that pushead had on his 33 but not white and 17inch
That white car looks damn similar to my car. I also have the upgrade interior, the high stop light in the spoiler and fog lamps like that. But i have aftermarket wheels, i dont have a special key and my gt badges are either repainted or not the gold ones.
So maybe im not special afterall. :worship:
Do all R32s have a crome grill trim? You know the little bit under the bonnet lip? Or is this special?
Commemorative keys
GT-R rims on M Spec
so basically it was just a slightly factory riced version? :worship:
It included:
Aluminum bonnet
Red SKYLINE Sticker
R Badge
Gold GT badge
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
