Wtb: R32 Gtr Front Drivehsaft Clip
How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate? How is it launching with it, any dragy times from 0-60? 60ft?
By svenskalice · Posted
Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine ! -
There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
