* Black Lenso D2r 18x9.5" +12 (bought march this yr), with just over 500kms use in new cond with no marks $1100
Also have tyres to suit, 255/35/18 and are all Run flats, 2xMichelin Pilot sports off the new M3 been told there $800-900 new, the other pair are bridgestone potenza re050a. At a guess they would have roughly 80-90% tread with slight camber wear $400
OR $1400 for the lot
* R32Rear parcel shelf 12mm chip board and black carpet to suit 6x9" speakers $20
* Ford EL thermo fans (have modified the shroud to try and make them fit but didn't work out) still usable in another setup $40
*Racepace adj cam gears $60
*Will also be selling my Power fc d-jetro soon (few months time) if anyone is interested
Have heaps of other left over parts from previous cars i've stripped eg. air con setups, power steering pumps, alternators, and more little bits and pieces.
Pick up only for large items from Eltham (melb) 30mins N.E. of the city
PM Q's or to [email protected] or call 0417 125 253 Cheers Elliot
hey elliot what do the cam gears suit?
Hey, there from an rb26, they'll fit rb20 and rb25's too, If you have Vct i think you lose the function of it with adj cam gears.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
