sweet........
santa dropped by my place early this year :ninja:
most of my shiet have arrived.
big things such as exhaust/fmic ill get later on just before i fit the stuff up.
all i need now is ecu (tossing up between PFC or emanage), exhaust, fmic, & im done!!!!!!!!!
fuelpump, oil line & bleed valve/boost tee coming :laugh:
big thanks to all who supplied the parts to me;
justjap, rocket racing, niteworks, and users on sau.com & ns.com!
And you're staying first quarter next year you'll have it all done?? Yeah Right!!! You won't last, you'll have all this in by xmas won't ya :D
I'm still finalising a few things but I'm hoping to have up n running this month in time for Xmas ;) Earlier would be better, should there be any other issues afterwards xmas wouldn't be the best time to sort them out lol
Can someone confirm the difference between an R34 4 Door Catback Exhaust and a 2 Door? One workshop tells me that they will be able to supply a second hand jap catback and that it won't matter if it's a 2 door? Or would they just customise it a bit? Oh that's another thing I don't have yet either..a turbo timer. I guess these can be easily added later though.
yeah turbo timers are easy to find for $50 & under.
4dr & 2dr catbacks are the same.
SSS autos in syd confirmed this for me.
and i found out that its the same in R32/R33's as well.
lol narh it will definately be next year, im saving up for PFC now..
let me know how u go with it ndawg.
got my turbosmart ultra gate & screamer today! WOOT!
niiiice!!! Well that clears things up then... I've seen exhausts listed as being for 2 door and others for 4 door specifically, but yeah now that I've got a second confirmation that makes things a bit easier with buying an exhaust now.
Hey Vikz...you still selling your zorst? hehehe
What's the difference between the N/A and GTT radiator? Is there much difference? I would to an extent base a decision on that. If Nissan have used the same radiator then go with that initially.
After doing the conversion, see how it goes with the stock radiator, and then make a decision whether to invest in an aftermarket radiator.
I never had any issues with overheating, to be honest the only time I ever saw the needle move from its normal position was in 38 degree heat in stationary traffic on Smith St after sitting there for 30mins
hey now i hope no one just tells me to read the full 19 pages which i did but wondering....
has anyone got a full list of the parts needed to do a turbo conversion to an rb25de?
gonna do it to my series 2 GTS4 and will make a full topic about with pictures and everything just need the full list of parts first thanks!
Also in this thread are some pics of the top of my engine using stock R33 parts for plumbing, you could get a custom made 90 degree with BOV flange made, that would be prettier :( Ignore the dirt, it had been sitting at the recovery impound yard for a bit.
http://www.skylinesaustralia.com/forums/R3...um-t243157.html
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
