Excellent advise here! Never ride a big bike again and have your memory erased so cant remember what it was like. Cheapest way out of this.
I drove a 2L diesel van for 6 months whilst my car was off the road, peak power at 2500rpm and a redline of about 3200, that and it was about 20m off the ground, after that even my mums 1.5L civic felt fast!
  • Replies 107
I do get that feeling also, I drive a truck for a living... 62tonne B-Double not exactly the fastest accelerating machine!
GTR feels like a Go-Kart after 12hrs driving.
I spend a few hours a day trolling threads and reading different results from peoples setups.
I'm set on getting to the 400kw mark when the time for upgrade comes so instead of have a toy in garage, I have a "Silly Toy"
Edited by Turbo Dave
  • 1 month later...
As much as I'd like to deny it, I am good friends with Ash. He's more misunderstood than a real tossbag :(
I did run an 11.2@127MPH with 347awkw on a stock 2.6L bottom end and 2860-5 with 19psi and super safe tune as dynoed at RE Customs. Drove in with 1/2 tank of fuel, dropped tyre pressures, ran back to back 11.2 and 11.3 along with 3-4 other runs which weren't as good, drove out to servo, pumped up tyres, filled petrol, drove home. Easy.
400rwkw on street tyres will net a 10 sec pass as long as you can launch properly. Everything in a GTR is at launch. After that, it's a pretty simple game.
I wouldn't be surprised if Ash does run a 10 with 400awkw. Even he couldn't fark up something this easy. LOL!
Well given he is a good friend of mine and we were actually discussing it yesterday, I'd be inclinded to believe my version. :D
You aren't the only one, plenty of cars out there are using factory dumps and making 330-380rwkw.
If you are so dead certain the car doesn't have anywhere near the power spend $80 and put it on another dyno and see, would be the first thing i'd do.
(i've gone from racepace to dr.drft, varience of a whopping 10rwkw)
Anyway, proof will be in the pudding - I'll remember this thread for a time when i run a 10 with factory dumps and -5's!
Till then :(
As much as I'd like to deny it, I am good friends with Ash. He's more misunderstood than a real tossbag :D
This is highly relevant to my interests, do you mind sharing your set up or specs ? that's pretty farken quick :thumbsup:
It was all pretty stock standard built engine mods I guess.
Intake & Exhaust
- Trust Drag 4" front mount intercooler (Twin entry)
- Custom 4" dump pipe from Turbo
- Apexi GT Spec 3.5" exhaust from dump pipe
- External (Screamer) 3.5" Seperate pipe on the Wastegate
Engine
Top End
- RB26DETT i6 24valve twin cam head
- Rod Smith Custom Group A cams
- Tomei Valve springs
- HKS 1.2mm metal head gasket
- HKS adjustable cam gears
Bottom End
- Wiesco Forged Pistons
- Nizmo Group A rods
- Balanced & machined crank
- HKS Oil pump
- GTR water pump
- ACL bearings
Turbo, ECU & Fuel
- Twin 2860-5
- Stock GTR piping
- Autronic SMC ECU modified for a GTR
- Autronic CDI
- Trust Profec B Boost Controller
- Aftermarket Jap 880cc twin feed Injectors.
- 2x Bosch 979 Fuel Pumps fed by stock GTR intank fuel pump.
- Custom built Racepace Motorsport oil catch can
- HKS ETC with drag apaptor
Drivetrain
- OS Giken Cross Mission gearset in Nissan factory housing with billet sandwhich plate
- Custom Built Jim Berry Clutch within Ogura Triple Plate Housing (4400lb Clamping Pressure)
Suspension & Brakes
- Tien RA fully adjustable coilovers
- 4 Piston Brembo Calipers front with EBC Greenstuff pads
- 2 Piston Brembo Calipers rear with EBC Greenstuff pads
Appearance
- 18x10.5 Bronze Weds SA90 forged rims
- 265/35/18
- 265/35/18
- Nismo style rear spats
- Tinted Windows
Interior
- Sparco race pedals
- Momo Race Steering Wheel
- Blitz 340 km/h dash
- Nismo center gauges
- Blitz DC Turbo Timer and boost gauge
Sound System
- Alpine head unit
- Alpine 12 disc stacker in boot
- Alpine front splits
- Alpine rear speakers
- 2x Alpine V12 amps
Intake & Exhaust
Engine
Top End
Bottom End
- HKS Oil pump
- GTR water pump
- ACL bearings
Turbo, ECU & Fuel
- Twin 2860-5
- Stock GTR piping
- Autronic CDI
Drivetrain
Suspension & Brakes
Appearance
- 265/35/18
- 265/35/18
- Tinted Windows
Interior
Sound System
- Alpine head unit
Awesome,
Cheers mate.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
