Hi guys,
At the last DECA I was giving the car a workout and found that the steering developed an intermittent dead spot in the centre. I had the passenger grab the wheel at one stage to prove I wasn't going crazy.
The car is an S13, CA, and I'd assume it's the original rack, it certainly doesn't look reco'd. I'm assuming rack as the tie rod ends looked fine, no bends, threads are good, no free play that I can easily get to happen up on stands. Rack mounts and bushes "look" OK to me but I'm no steering specialist. I topped up the power steering reservoir and thought it got better but then it came back, it seem to be when loading the car up hard side to side on the skid pan, which to me implied a hydraulic issue in the rack. The boots on the end of the rack aren't filled with fluid so I'd say the seals at the end of the rack are good, no leaks that I can see.
At it's worst there's probably a good 20-25 degrees dead space in each direction from centre.
I had 235 semi's on it at the time, -2.5 deg camber. Can't recall toe/castor settings right now.
Thoughts?
you need to determine where the freeplay is exactly. jack it up and get some one to turn the wheel in the freeplay back and forth and check everything,
what colour is the powersteer fluid? is it burnt?
It's on stands at the moment and I'll be doing that but when it was intermittent and seemed relative to lateral load on the car durnig cornering.
Fluid is standard colour, didn't look any different to what came out of the bottle when I topped it up and didn't smell burnt.
I'll be getting under it in the next few days.
OK here's what I found.
Car up on stands, me lying on my bak with the leadlight, GF turning the wheel.
Mechanically I can't see any free play, I had the GF do fast and slow turns full lock in both directions with and without me providing enough resistence on the wheels to stop her being able to turn the wheel in the cabin.
I also had her hold the wheel hard while I tried to make each wheel turn, no freeplay there.
What I did find is that one rack boot has a split in it and inside I can see brown grease. Without cmoparing to the other one I'm not sure if it should be that colour or not. If it shouldn't be covered in crud then I suspect that when the rack has a lot of pressure on it there may be fluid getting past the outer seal and into the boot, however the boot didn't show signs of large amounts of fluid - maybe early days for the leak.
I also noted that the inner part of the tie rod where it joins the rack has been bent back, I'd say from hitting the rack on full lock turns too hard.
I also note that the outer tie rod ends/pins that connect to the wheel hub assembly have split boots on both sides. I'm a bit vague on terminology, sorry.
Thougths? Mechanically it looks and feels ok. A mate was telling me there's a valve where the steering column knuckle joins the top of the rack and they are common failure points just for something extra to consider.
Thanks so far guys :D
A bent rack end will cause that, as it spins around it can play havok, but unlikey due to your diagnosis.
If you don't know how to diagnose problems its hard to rule anything out.
There are only a few links in the steering (5 if you count the rack bushes)
Jack it up, grab the wheel at 3 and 9 o clock. Keep steering the tyre back and forth by hand, If you feel any freeplay, your getting somewhere. Get a mate to do the same while you watch closley at each steering part to see whats got free play.
To me it sounds like the rack is stuffed, Ive never heard of the gears loosing a tooth, but it might be possible.
Could also be a caster rod bush/bearing gone, it might be binding the steering.
To test your rack bushes put it on the ground, get 5 fat mates to sit in the engine bay, then you get under the car and watch the rack while your girlfriend steers left to right throughout its whole range.
5mm of movement is normal, any more or abnormal movement is a bad sign, as under load with semis the problem compunds.
Really its impossible to diagnose over the internet.
This leads me to believe the outer seal in the rack is weeping under pressure? I assume this requires a rebuild?
Bad side
Good side
Edited by ActionDan
also, check the drivers side rack bush. it is usually covered in oil and perished. with the car on the ground jiggle the steering wheel. you will be able to see the rack move side to side if it is worn.. this can feel like freeplay when driving.
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
