Hey all today I have a 1992 subaru liberty gx awd for sale
GOOD POINTS:
Its dark green/black
Lowered lovells springs
Green Neons in boot
Kenwood headunit aux input
Kenwood speakers in custom made door pods
10" kenwood sub in box
2x 10" pioneer subs no boxes
All amp wiring and rcas installed with capaictor and second set of rcas
New alternator cost $320
New battery cost $100
Sony explode speakers in parcel shelf
Sports exhaust
Auto
283xxxklms
BAD POINTS:
I was driving allong and the harmonic balancer came off as well as the belts so
I went too the wreckers and bought a new one and chucked it on all sweet for
About a week or two driving along again and it starts running rough so I pull over
Too see what's wrong harmonic balancer is loose I thought that's strange so I get
It towed had my mechanic look over it this time tells me the keyway is f**ked and its
Thrashing out my harmonic balancers and its slipped the timing belt so I've bought a
Harmonic balancer and have a keyway lined up other than that just need too redo
The timing with a timing light. He also told me my rear left hand rive shaft has a bit of
Play other than that its a great car. Few scrathes and dents. I can get this all fixed at an
Additional cost if you would like haven't had time as I'm in newcastle and the car played
Up when I was visiting my mum in harrigton so that's were it stayed.
12 MONTHS REGO.
I'm wanting $1500 as is or I can get it fixed for whatever it cost me
Contact jahn on 0432163488
I have been as honest as possible but come and inspect it
Can't get pics up atm ill try too in the next couple of days...
UPDATE! have balancer and everything fixed now. but the air flow sensor is stuffed or ecu not sure dont really want too
stuff around with it my mechanic has done a compression test come back ok he said this engine has like 36 sensors so could be any
one of those just running a bit rough $1000 TAKE IT AWAY really cheap for a car with 12 months rego....
Car is getting trucked back too newy and im going too fix it and bimp the price back up
Unless someone wants it as is may be able too deliver newcastle area
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
