Hey guys
I always feel a weird knocking sound from the chassis when the car is idle and I went to the auto repair shop they told me it may cause by the bad fuel damper. You can actually feel the pulse from the fuel line and its exactly the same rhythm as the knocking noise. Anyone have any idea how much the fuel damper cost? I am planning to import the parts from US but not sure they are the same or not. BTW I am thinking the fuel damper should be the same model as 350Z...anyideas?
https://www.sau.com.au/forums/topic/335124-fuel-damper/
It's a known issue with the VQ engine and I've recently replaced mine with a damper from Riverside Infiniti USA.
They sell for about $120AU shipped. Local dealers wanted $300 for it...
Hey guys
https://www.sau.com.au/forums/topic/335124-fuel-damper/#findComment-5425089
Thanks for your information. Can you please tell me where can I order one from? May be I can order one from US and ask someone to put it in. :D
https://www.sau.com.au/forums/topic/335124-fuel-damper/#findComment-5425343
The one that's usually faulty is on the left bank (when facing the engine) and has the rubber hose that feeds straight from the fuel line.
Part number is 22675-AM60A - Fuel feed hose damper
Another thing you can do to test if the existing damper is faulty is to touch the fuel feed hose from the damper during idle.
If it vibrates a fair bit like the noise from inside the car, then its faulty.
I think I may also need one of these, which fuel damper is generally the faulty one, as there's one for each bank?
https://www.sau.com.au/forums/topic/335124-fuel-damper/#findComment-5426760
You can also contact Rick at Riverside Infiniti here:
[email protected]
Thanks for that. I never try to buy part online before, can anyone please tell me how to do? Is that just contact the guy by email and transfer the money to his account then he will sent the part to you? Cheers. :):D:D:P
https://www.sau.com.au/forums/topic/335124-fuel-damper/#findComment-5428335
  • 2 years later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
