been playing alot more of this since i buggered my wrist and cant play GT5. seems everyone has a warrior now.
im lvling my second warrior atm, a gobo. and i must say i love how they've livened up the low lvl questing, you move on faster, and all the areas are revamped etc. just good to see a change, and fun again to lvl a lowbie.
FURY ftw
Edited by boiracer
Yeah my warrior is 83, fury spec, and about 1/3 of my gear is prot, but with the huge amounts of strength even from quests reward/dungeon blue gear, I can comfortably do 8000-10,000 dps.
I haven't yet tried tanking in Cata dungeons, but I assume it wouldn't be that much different to level 80 WotLK heroics.
All in all, really enjoying my warrior - has 89,000 hp when buffed :D
What are rogues like to level (quests/dungeons etc)? I have a level 12 rogue I think, with full BOA's and enchants. Good to play so far and doesn't seem like too much downtime.
Also have a 70 warlock in BOA's....also good to level and to play @ end game??
I like the hardness more of a challenge. + I hate how they turned epics into welfare in BC / WOTLK back to normal now.
Yeah, that's why I like Cata so much more than WotLK...epic gear seems a lot harder to acquire, just like it was a real challenge to get it in Vanilla....however, even though you could get epic gear kind easily in BC, it was still quite difficult to get good quality epic gear in BC (through SSC, TK, Hyjal & BT).
Any who, I'll be looking forward to hitting 85, getting lots of heroics done and slowly gearing up towards some raids :)
tanked my first heroic last night...........
FINALY
and was only cos the rest of the group was a guild and they were geared lolz
no tank drops.... fml
Edited by Clutch
FINALY
ha! by the sounds of it, you got stiffed!
Have you not got any of the epic 85 gear from reputation factions?
If you get exalted with the Guardians of Hyjal, you can get epic quality tanking plate boots. Im already halfway to revered through quests and shit.
There is some decent gear, but it will take a while to get good quality epics and be a f**king huge karnt tank with 5zillion hp.
im disappointed with wow lately, decided to play the other night, went in que for a bg, it said recommended wait time 2 mins, and i waited 20, and still nothing, so i stopped playing again...
BG's are gay though. The only time i ever BG'd was in Burning Crusade to get the pvp gear for my warlock so i could get into Karazhan LOL. And the only BG i ever did was Alterac Valley....when the wait time was at least 1.5 hours and horde never used to loose!
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
