  • Replies 106
Hi glad i found this site...
Heres my build so far in a nutshell there will be more to come :)
Bought this about 1 year ago
a small bit of wee came out when the owner took me for a test drive
so i took it home then the fun/pain started
Step 1 service parts.
water pump
cam seals
all the bearings
trust timing belt
all the accesory belts
yadda yadda
then picked up a set of splitfire ignitioncoils from a guy in sunnybank
got a good price so happy times
then installed install the apexi super flow air filter kit
a very nice kit and well presented
goes together o.k
instructions are so so
then got some alloy subframe collars
OH YEAH!
then replaced this seal
then ordered a new stainless exhaust from jdm land
i then lost the rear turbo :banana: so i ordered these bad mofo's
Garrett GT2860R-5 good for 360 hp each specs below
GT2860R-707160-5 turbo changers which are direct replacement items for the Nissan skyline R32/33/34 GTR. They are rated to 360hp each, 720hp combined, and have the following specifications:
* Ball bearing
* Oil & Water-cooled bearing system
* T25 turbine inlet flange with threaded bolt holes instead of traditional through holes
* Turbine housing has a unique "compact" 5-bolt outlet that is not interchangeable with traditional T25 5-bolt outlets
* Turbine housing is cast from high-nickel "Ni-Resist" material for extreme applications
* Turbine wheel is cast from "Inconel" material for extreme applications
* Direct replacement upgrade turbocharger for GT2556R (702987-7) used on Nissan Skyline R34 GT-R
* Great size for applications w/ packaging constraints
* Ideal for smaller displacement engines making up to 360 hp
* Turbine housing option available
* Turbine housing options allow turbo to be outline-interchangeable with other turbos using the traditional 5-bolt turbine housing. Housing fits over turbine wheel but actuator/wastegate fitment may need to be adjusted.
i also bought some dumps
pic of asshole spider in my closet - now i cant go in and get a shirt so very scared
new engine and box mounts
ok so the turbo swap starts and so begins 12 hours of fun
grabbed some purple as well
brad had to take some meat from the turbine housings to match to the new manifolds
as you can see below a fair bit had to go
installing the new studs
dumps joined
hey man, what are the threads and sizes of the studs as i need to buy some ?
https://www.sau.com.au/forums/topic/335595-my-32gtr/page/6/#findComment-5572934
Call Nissan with your VIN or GCG - they will be able to supply them and will know the sizes. Make sure you get inconel ones and not just high tensile for the turbo hot side - high tensile tend to stretch from heat + gravity.
https://www.sau.com.au/forums/topic/335595-my-32gtr/page/6/#findComment-5573021
  • 5 months later...
