Hi
I'm selling my car due to moving/life style change.
Long story short the car had a wonderfull 2 years with out any major issues. Replaced clutch/New second gear box (due to old one stuff)/Second Hand turbos while I saved for new 2860-5. Last year around this time I went for a cruise to Northampton and back from Geraldton. 90km round trip. On the last stretch the 5th cynder lost compression and I crawled home. I ripped out the old engine and start a R26/30 conversion with GT2860-5 turbos.
This is where the car stands now. Engine is nearly complete. Car is nearly ready.
I'm selling the lot.
Car/engine/old engine/ALL of my spare parts.
15K ONO
This includes
Engine
Rebuilt RB30 bottom end with ACL bearings,
Pro Engines 4WD adaptor plate.
Acid dip block with new Welsh plugs.
New ACL pistons with bores to suit. 20tho over size.
GT2860 - 5 Turbos
New water pipping kit
New DBA rotars
And many more i can't remember....
Car
1993 Bayside Blue GTR
All Power Options
Volk Racing challange 17" Alloys
HKS Adjustable coil over suspension
HKS Exhaust
HKS Big 2- Way Intercooler
Momo Steering Wheel
Turbo Timer
HKS Meters x 3
Alphine audio system
Nismo Rear Lip Spoiler
Sports Clutch
N1 Headlights
From when I brought it from imports101
http://www.imports101.com.au/view.php?car=1619
I have since added:
New radiator, Nice and thick and ali. Improved temps 10 fold. Old one had it's top tanks splitting.
New Twin plate Clutch Extreme (Installed by Hyperdrive Perth)
Stereo (2 x 12" subs, 6" splits, 6" with new parcel shelf and 3 amps.)
Always service with MOTUL oils every 6months or 5000kms.
All oils where replaced with new oils within 6months of owning it.
New Rims brought off these furoms. CST Hyper Z's (Heaps of comments about these.) http://www.skylinesaustralia.com/forums/Cs...er-t218119.html
HKS x2 SSQ Blow off values
Rust cut out of the back windscreen. Some dickhead reversed into me and while that got fix, I cut the rust out as well. Rust free again.
Spares:
Rb26 complete short block.
3 Rims with 1 rim having a crack in it.
Everything thing to make the car stock. EG original BO values.
Bad things.
Car need to be put back together (durr)
Rear spoiler lip is failing apart.
Front lip has been damaged to much. Was trying to get a replacement but now selling the car.
This car has pasted the pit many times with any issues.
It was my daily driver and always washes and cleaned. I'm sad to see it go but i'm afraid that I have lost all motivation.
here is a vid of it at the Show and Shine held in Geraldton.
The car is still regoed till next year.
Once again open to all offers.
15K ONO
Cheers.
PS. I might of forgot to mention some spare parts but you can pic and chose.
Some photos I got on Facebook.
http://www.facebook.com/album.php?aid=2011...mp;l=a209b794de
Edited by whiteboy01
https://www.sau.com.au/forums/topic/335745-r32-gtr-rb2630-bayside-blue/
Sorry Location is Geraldton 6530
Can get it to Perth as well.
Had a few PM's for my phone number so here it is .
If I don't answer leave a msg and I will get back to you.
Cheers
PS also got current photos if you want to see them send me your email. Thanks.
Edited by R31Nismoid
Had a few PM's for my phone number so here it is 0400210338.
Cheers
Bumpy
  • 3 weeks later...
these are my favourite cars man, i got a 32 gts-t..my dream is own one but dont have the cash atm..good luck with the sale
PRICE DROP 14K ONO
Will drive to Perth for delivery.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
